Datasheet LT3007 (Analog Devices) - 5
Description3μA IQ, 20mA, 45V Low Dropout Fault Tolerant Linear Regulators
Pages / Page20 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 344 Kb
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Dropout Voltage. Minimum Input Voltage
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted Dropout Voltage Minimum Input Voltage
LT3007
LT3007 Series
LT3007 Series
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Dropout Voltage Dropout Voltage Minimum Input Voltage
450 450 2.0 ILOAD = 20mA 400 400 1.8 350 TJ = 125°C 350 1.6 TJ = 150°C 20mA 300 300 1.4 10mA 1.2 TAGE (mV) 250 TJ = 25°C TAGE (mV) 250 1 200 200 1mA 0.8 150 150 100µA 0.6 DROPOUT VOL 100 DROPOUT VOL 100 0.4 MINIMUM INPUT VOLTAGE (V) 50 50 0.2 0 0 0 0 5 10 15 20 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 OUTPUT CURRENT (mA) TEMPERATURE (°C) TEMPERATURE (°C) 3007 G01 3007 G02 3007 G03
ADJ Pin Voltage Output Voltage LT3007-1.2 Output Voltage LT3007-1.5
0.612 1.224 1.530 I I I 0.610 LOAD = 100µA 1.220 LOAD = 100µA 1.525 LOAD = 100µA 0.608 1.216 1.520 0.606 1.212 1.515 0.604 1.208 1.510 0.602 1.204 1.505 0.600 1.200 1.500 0.598 1.196 1.495 0.596 1.192 1.490 ADJ PIN VOLTAGE (V) 0.594 OUTPUT VOLTAGE (V) 1.188 OUTPUT VOLTAGE (V) 1.485 0.592 1.184 1.480 0.590 1.180 1.475 0.588 1.176 1.470 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3007 G05 3007 G06 3007 G04
Output Voltage LT3007-1.8 Output Voltage LT3007-2.5 Output Voltage LT3007-3.3
1.836 2.550 3.366 I I I 1.830 LOAD = 100µA LOAD = 100µA LOAD = 100µA 2.540 3.355 1.824 3.344 2.530 1.816 3.333 2.520 1.812 3.322 1.806 2.510 3.311 1.800 2.500 3.300 1.794 2.490 3.289 1.788 3.278 OUTPUT VOLTAGE (V) 2.480 1.782 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 3.267 2.470 1.776 3.256 1.770 2.460 3.245 1.764 2.450 3.234 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3007 G07 3007 G08 3007 G09 3007fa For more information www.linear.com/LT3007 5
