Datasheet LT3008 (Analog Devices) - 7
Description3μA IQ, 20mA, 45V Low Dropout Linear Regulators
Pages / Page20 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. …
File Format / SizePDF / 242 Kb
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Dropout Voltage. Minimum Input Voltage. Output Voltage
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted Dropout Voltage Minimum Input Voltage Output Voltage
LT3008
LT3008 Series
LT3008 Series
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Dropout Voltage Dropout Voltage Minimum Input Voltage
450 450 2 ILOAD = 20mA 400 1.8 400 TJ = 125°C 1.6 350 350 20mA 1.4 300 TJ = 25°C 300 10mA 1.2 TAGE (mV) 250 TAGE (mV) 250 1 200 200 1mA 0.8 150 150 100μA 0.6 DROPOUT VOL 100 DROPOUT VOL 100 0.4 MINIMUM INPUT VOLTAGE (V) 50 50 0.2 0 0 0 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 0 2 4 6 8 10 12 14 16 18 20 OUTPUT CURRENT (mA) TEMPERATURE (°C) TEMPERATURE (°C) 3008 G01 3008 G02 3008 G03
Output Voltage Output Voltage ADJ Pin Voltage LT3008-1.2 LT3008-1.5
0.612 1.224 1.530 I I I 0.610 L = 100μA 1.220 LOAD = 100μA 1.525 LOAD = 100μA 0.608 1.216 1.520 0.606 1.212 1.515 0.604 1.208 1.510 0.602 1.204 1.505 0.600 1.200 1.500 0.598 1.196 1.495 0.596 1.192 1.490 ADJ PIN VOLTAGE (V) 0.594 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 1.188 1.485 0.592 1.184 1.480 0.590 1.180 1.475 0.588 1.176 1.470 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3008 G05 3008 G06 3008 G04
Output Voltage Output Voltage Output Voltage LT3008-1.8 LT3008-2.5 LT3008-3.3
1.836 2.550 3.366 I ILOAD = 100μA ILOAD = 100μA 1.830 LOAD = 100μA 2.540 3.355 1.824 3.344 2.530 1.816 3.333 2.520 1.812 3.322 1.806 2.510 3.311 1.800 2.500 3.300 1.794 2.490 3.289 1.788 3.278 2.480 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 1.782 3.267 2.470 1.776 3.256 1.770 2.460 3.245 1.764 2.450 3.234 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3008 G07 3008 G08 3008 G09 3008fc 7
