Datasheet LT3010, LT3010-5 (Analog Devices) - 2
Description50mA, 3V to 80V Low Dropout Micropower Linear Regulator
Pages / Page18 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
File Format / SizePDF / 415 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3010/LT3010-5
IN Pin Voltage .. ±80V OUT Pin Voltage ... ±60V TOP VIEW IN to OUT Differential Voltage .. ±80V OUT 1 8 IN ADJ Pin Voltage ... ±7V SENSE/ADJ* 2 9 7 NC NC 3 GND 6 NC SHDN Pin Input Voltage ... ±80V GND 4 5 SHDN Output Short-Circuit Duration ... Indefinite MS8E PACKAGE 8-LEAD PLASTIC MSOP Storage Temperature Range .. –65°C to 150°C *SENSE FOR LT3010-5, ADJ FOR LT3010 Operating Junction Temperature Range TJMAX = 125°C (LT3010E/LT3010MP), θJA = 40°C/W, θJC = 16°C/W† TJMAX = 140°C (LT3010H), θJA = 40°C/W, θJC = 16°C/W† (Notes 3, 10, 11) SEE APPLICATIONS INFORMATION SECTION. EXPOSED PAD (PIN 9) IS GND, MUST BE SOLDERED TO PCB LT3010E ... –40°C to 125°C †MEASURED AT BOTTOM PAD LT3010H .. –40°C to 140°C LT3010MP.. –55°C to 125°C Lead Temperature (Soldering, 10 sec) ... 300°C
LT3010EMS8E#PBF LT3010EMS8E#TRPBF LTZF 8-Lead Plastic MSOP –40°C to 125°C LT3010EMS8E-5#PBF LT3010EMS8E-5#TRPBF LTAEF 8-Lead Plastic MSOP –40°C to 125°C LT3010HMS8E#PBF LT3010HMS8E#TRPBF LTCLP 8-Lead Plastic MSOP –40°C to 140°C LT3010HMS8E-5#PBF LT3010HMS8E-5#TRPBF LTCLQ 8-Lead Plastic MSOP –40°C to 140°C LT3010MPMS8E#PBF LT3010MPMS8E#TRPBF LTZF 8-Lead Plastic MSOP –55°C to 125°C LT3010MPMS8E-5#PBF LT3010MPMS8E-5#TRPBF LTAEF 8-Lead Plastic MSOP –55°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3010EMS8E LT3010EMS8E#TR LTZF 8-Lead Plastic MSOP –40°C to 125°C LT3010EMS8E-5 LT3010EMS8E-5#TR LTAEF 8-Lead Plastic MSOP –40°C to 125°C LT3010HMS8E LT3010HMS8E #TR LTCLP 8-Lead Plastic MSOP –40°C to 140°C LT3010HMS8E-5 LT3010HMS8E-5 #TR LTCLQ 8-Lead Plastic MSOP –40°C to 140°C LT3010MPMS8E LT3010MPMS8E#TR LTZF 8-Lead Plastic MSOP –55°C to 125°C LT3010MPMS8E-5 LT3010MPMS8E-5#TR LTAEF 8-Lead Plastic MSOP –55°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
ELECTRICAL CHARACTERISTICS (LT3010E, LT3010MP) The
l
denotes the specifications which apply over the –40°C to 125°C (LT3010E) or –55°C to 125°C (LT3010MP) operating temperature range, otherwise specifications are at TA = 25°C. PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage LT3010 ILOAD = 50mA l 3 4 V Regulated Output Voltage LT3010-5 VIN = 5.5V, ILOAD = 1mA 4.925 5.000 5.075 V (Note 3) 6V < VIN < 80V, 1mA < ILOAD < 50mA l 4.850 5.000 5.150 V ADJ Pin Voltage (Notes 2, 3) LT3010 VIN = 3V, ILOAD = 1mA 1.258 1.275 1.292 V 4V < VIN < 80V, 1mA < ILOAD < 50mA l 1.237 1.275 1.313 V 30105fe 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
