Datasheet LT3013B (Analog Devices) - 6
Description250mA, 4V to 80V Low Dropout Micropower Linear Regulator with PWRGD
Pages / Page16 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Reverse Output Current. Input Ripple …
File Format / SizePDF / 178 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Reverse Output Current. Input Ripple Rejection. Minimum Input Voltage. Load Regulation
TYPICAL PERFORMANCE CHARACTERISTICS Reverse Output Current Input Ripple Rejection Minimum Input Voltage Load Regulation
LT3013B
TYPICAL PERFORMANCE CHARACTERISTICS Reverse Output Current Input Ripple Rejection Input Ripple Rejection
35 92 100 VIN = 0V VIN = 4.5V + 50mVRMS RIPPLE VOUT = VADJ = 1.24V 88 90 ILOAD = 250mA 30 80 84 25 70 80 60 20 76 50 COUT = 10μF 15 72 40 30 10 RIPPLE REJECTION (dB) 68 RIPPLE REJECTION (dB) V 20 IN = 4.5V + 0.5VP-P RIPPLE AT f = 120Hz REVERSE OUTPUT CURRENT (μA) 5 64 IL = 250mA 10 COUT = 3.3μF VOUT = 1.24V 0 60 0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 10 100 1k 10k 100k 1M TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (Hz) 3013 G17 3013 G18 3013 G19
Minimum Input Voltage Load Regulation Output Noise Spectral Density
4.0 0 ) 10 ILOAD = 250mA $I C L = 1mA TO 250mA Hz OUT = 3.3μF 3.5 –2 ILOAD = 250mA –4 3.0 –6 1 2.5 –8 2.0 –10 1.5 –12 0.1 –14 1.0 LOAD REGULATION (mV) MINIMUM INPUT VOLTAGE (V) –16 0.5 –18 0 –20 OUTPUT NOISE SPECTRAL DENSITY (mV/√ 0.01 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 10 100 1k 10k 100k TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (Hz) 3013 G20 3013 G21 3013 G22
10Hz to 100Hz Output Noise Transition Response
0.15 0.10 0.05 0 VOUT 100μV/DIV –0.05 DEVIATION (V) V OUTPUT VOLTAGE IN = 6V –0.10 VOUT = 5V –0.15 CIN = 3.3μF CERAMIC COUT = 3.3μF CERAMIC 300 $ILOAD = 100mA TO 200mA 200 1ms/DIV 3013B G23 COUT = 10μF I 100 L = 250mA VOUT = VADJ LOAD CURRENT (mA) 0 0 100 200 300 400 500 TIME (μs) 3013 G24 3013bfb 6
