Datasheet LT3029 (Analog Devices) - 9
DescriptionDual 500mA/500mA Low Dropout, Low Noise, Micropower Linear Regulator
Pages / Page20 / 9 — Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. …
Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. 10Hz to 100kHz Output Noise,. CBYP = 0pF. CBYP = 100pF
Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted 10Hz to 100kHz Output Noise, CBYP = 0pF CBYP = 100pF
LT3029
Typical perForMance characTerisTics TJ = 25°C, unless otherwise noted. 10Hz to 100kHz Output Noise, 10Hz to 100kHz Output Noise, CBYP = 0pF CBYP = 100pF
VOUT VOUT 100µV/DIV 100µV/DIV 3029 G29 3029 G30 1ms/DIV 1ms/DIV COUT = 10µF COUT = 10µF IL = 500mA IL = 500mA VOUT = 5V VOUT = 5V
10Hz to 100kHz Output Noise, 10Hz to 100kHz Output Noise, CBYP = 1000pF CBYP = 0.01µF
VOUT VOUT 100µV/DIV 100µV/DIV 3029 G31 1ms/DIV 3029 G32 1ms/DIV COUT = 10µF COUT = 10µF IL = 500mA IL = 500mA VOUT = 5V VOUT = 5V 3029fb For more information www.linear.com/LT3029 9 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
