Datasheet LT3080-1 (Analog Devices) - 2
DescriptionParallelable 1.1A Adjustable Single Resistor Low Dropout Regulator
Pages / Page24 / 2 — absoluTe maximum raTings (Note 1) All Voltages Relative to VOUT. pin …
File Format / SizePDF / 354 Kb
absoluTe maximum raTings (Note 1) All Voltages Relative to VOUT. pin conFiguraTion
absoluTe maximum raTings (Note 1) All Voltages Relative to VOUT pin conFiguraTion
LT3080-1
VCONTROL Pin Voltage ..40V, –0.3V Operating Junction Temperature Range (Notes 2, 10) IN Pin Voltage ..40V, –0.3V E-, I-grades ..–40°C to 125°C SET Pin Current (Note 7) ... ±10mA Storage Temperature Range ..–65°C to 150°C SET Pin Voltage (Relative to OUT) ...±0.3V Lead Temperature (Soldering, 10 sec) Output Short-Circuit Duration .. Indefinite MS8E Package Only ..300°C
pin conFiguraTion
TOP VIEW TOP VIEW OUT 1 8 IN OUT 1 8 IN OUT 2 9 7 IN OUT 2 9 7 IN OUT 3 OUT 6 NC OUT 3 OUT 6 NC SET 4 5 V SET 4 5 V CONTROL CONTROL MS8E PACKAGE 8-LEAD PLASTIC MSOP DD PACKAGE TJMAX = 125°C, θJA = 60°C/W, θJC = 10°C/W 8-LEAD (3mm × 3mm) PLASTIC DFN
EXPOSED PAD (PIN 9) IS OUT, MUST BE SOLDERED TO PCB
TJMAX = 125°C, θJA = 64°C/W, θJC = 3°C/W
EXPOSED PAD (PIN 9) IS OUT, MUST BE SOLDERED TO PCB orDer inFormaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3080EDD-1#PBF LT3080EDD-1#TRPBF LDPM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3080IDD-1#PBF LT3080IDD-1#TRPBF LDPM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3080EMS8E-1#PBF LT3080EMS8E-1#TRPBF LTDPN 8-Lead Plastic MSOP –40°C to 125°C LT3080IMS8E-1#PBF LT3080IMS8E-1#TRPBF LTDPN 8-Lead Plastic MSOP –40°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3080EDD-1 LT3080EDD-1#TR LDPM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3080IDD-1 LT3080IDD-1#TR LDPM 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3080EMS8E-1 LT3080EMS8E-1#TR LTDPN 8-Lead Plastic MSOP –40°C to 125°C LT3080IMS8E-1 LT3080IMS8E-1#TR LTDPN 8-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 30801fc 2 For more information www.linear.com/LT3080-1 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
