Datasheet LT3082 (Analog Devices) - 2
Description200mA Single Resistor Low Dropout Linear Regulator
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1) All Voltages Relative to VOUT. PIN …
File Format / SizePDF / 301 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1) All Voltages Relative to VOUT. PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH
ABSOLUTE MAXIMUM RATINGS (Note 1) All Voltages Relative to VOUT PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH
LT3082
IN Pin Voltage Relative to SET, OUT ..±40V Operating Junction Temperature Range (Notes 2, 8) SET Pin Current (Note 6) ...±15mA E, I Grades ... –40°C to 125°C SET Pin Voltage (Relative to OUT, Note 6) ...±10V MP Grade ... –55°C to 125°C Output Short-Circuit Duration .. Indefi nite Storage Temperature Range ... –65°C to 150°C Lead Temperature (ST, TS8 Packages Only) Soldering, 10 sec .. 300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW 3 IN OUT 1 8 IN TOP VIEW OUT 2 7 IN NC 1 8 IN 9 TAB IS OUT 2 OUT OUT 2 7 IN NC 3 6 NC OUT 3 6 NC SET 4 5 NC 1 SET OUT 4 5 SET ST PACKAGE TS8 PACKAGE DD PACKAGE 3-LEAD PLASTIC SOT-223 8-LEAD PLASTIC TSOT-23 8-LEAD (3mm s 3mm) PLASTIC DFN TJMAX = 125°C, θJA = 24°C/W, θJC = 15°C/W TJMAX = 125°C, θJA = 57°C/W, θJC = 15°C/W TJMAX = 125°C, θJA = 28°C/W, θJC = 3°C/W TAB IS OUT, MUST BE SOLDERED TO OUT ON THE PCB; EXPOSED PAD (PIN 9) IS OUT, MUST BE SOLDERED TO OUT ON SEE THE APPLICATIONS INFORMATION SECTION THE PCB; SEE THE APPLICATIONS INFORMATION SECTION
LT3082EDD#PBF LT3082EDD#TRPBF LDYT 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3082IDD#PBF LT3082IDD#TRPBF LDYT 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3082EST#PBF LT3082EST#TRPBF 3082 3-Lead Plastic SOT-223 –40°C to 125°C LT3082IST#PBF LT3082IST#TRPBF 3082 3-Lead Plastic SOT-223 –40°C to 125°C LT3082MPST#PBF LT3082MPST#TRPBF 3082MP 3-Lead Plastic SOT-223 –55°C to 125°C LT3082ETS8#PBF LT3082ETS8#TRPBF LTDYV 8-Lead Plastic SOT-23 –40°C to 125°C LT3082ITS8#PBF LT3082ITS8#TRPBF LTDYV 8-Lead Plastic SOT-23 –40°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3082EDD LT3082EDD#TR LDYT 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3082IDD LT3082IDD#TR LDYT 8-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3082EST LT3082EST#TR 3082 3-Lead Plastic SOT-223 –40°C to 125°C LT3082IST LT3082IST#TR 3082 3-Lead Plastic SOT-223 –40°C to 125°C LT3082MPST LT3082MPST#TR 3082MP 3-Lead Plastic SOT-223 –55°C to 125°C LT3082ETS8 LT3082ETS8#TR LTDYV 8-Lead Plastic SOT-23 –40°C to 125°C LT3082ITS8 LT3082ITS8#TR LTDYV 8-Lead Plastic SOT-23 –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3082f 2
