Datasheet LTC3035 (Analog Devices) - 2
Description300mA VLDO Linear Regulator with Charge Pump Bias Generator
Pages / Page12 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Notes 1, 2). Order …
File Format / SizePDF / 224 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Notes 1, 2). Order Options. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Notes 1, 2) Order Options ELECTRICAL CHARACTERISTICS The
LTC3035
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Notes 1, 2)
V TOP VIEW IN to GND .. – 0.3V to 6V SHDN to GND ... – 0.3V to 6V CP 1 8 BIAS CP, CM, BIAS to GND ... – 0.3V to 6V CM 2 7 SHDN ADJ to GND .. – 0.3V to 6V 9 GND 3 6 ADJ VOUT to GND ... – 0.3V to 6V IN 4 5 OUT Operating Junction Temperature (Note 3) ... – 40°C to 125°C DDB PACKAGE 8-LEAD (3mm × 2mm) PLASTIC DFN Storage Temperature Range .. – 65°C to 125°C TJMAX = 125°C, θJA = 76°C/W Output Short Circuit Duration .. Indefinite EXPOSED PAD (PIN 9) IS GND,MUST BE SOLDERED TO PCB ORDER PART NUMBER DDB PART MARKING LTC3035EDDB LBRM
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes specifications which apply over the full specified temperature range, otherwise specifications are at TA = 25
C. VIN = 3.6V, VOUT = 3.3V, CFLY = 0.1
µ
F, COUT = 1
µ
F, CIN = 1
µ
F, CBIAS = 1
µ
F (all capacitors ceramic) unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Operating Voltage (Note 4) ● 1.7 5.5 V VBIAS Output Voltage Range 2.63V < VIN < 5.5V ● 4.8 5 5.3 V 1.7V < VIN < 2.63V ● 1.85 • VIN 1.90 • VIN 1.95 • VIN V VOUT Output Voltage Range ● VADJ 3.6 V VIN Operating Current IOUT = 10µA ● 100 200 µA VIN Shutdown Current VSHDN = 0V 1 5 µA VADJ Regulation Voltage (Note 5) 1mA < IOUT < 300mA, 1.7V < VIN < 5.5V, ● 0.392 0.4 0.408 V VOUT = 1.5V IADJ ADJ Input Current VADJ = 0.4V ● –50 0 50 nA OUT Load Regulation (Referred to ADJ Pin) IOUT = 1mA to 300mA –0.2 mV Dropout Voltage (Note 6) VIN = 1.7V, VADJ = 0.37V, IOUT = 300mA ● 45 100 mV IOUT Continuous Output Current ● 300 mA IOUT Short Circuit Output Current VADJ = VOUT = 0 760 mA VOUT Output Noise Voltage F = 10Hz to 100kHz, IOUT = 150mA 150 µVrms VIH SHDN Input High Voltage ● 1.1 V VIL SHDN Input Low Voltage ● 0.3 V IIH SHDN Input High Current SHDN = VIN –1 1 µA IIL SHDN Input Low Current SHDN = 0V –1 1 µA
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 3:
The LTC3035 regulator is tested and specified under pulse load of a device may be impaired. conditions such that TJ ≈ TA. The LTC3035 is 100% production tested at
Note 2:
This IC includes overtemperature protection that is intended to 25°C. Performance at –40°C and 125°C is assured by design, protect the device during momentary overload conditions. Junction characterization and correlation with statistical process control. temperature will exceed 125°C when overtemperature protection is active.
Note 4:
Min Operating Input Voltage required for regulation is: Continuous operation above the specified maximum operating junction VIN > VOUT + VDROPOUT and VIN > 1.7V temperature may impair device reliability. 3035f 2
