Datasheet LTC3035 (Analog Devices) - 3
Description300mA VLDO Linear Regulator with Charge Pump Bias Generator
Pages / Page12 / 3 — ELECTRICAL CHARACTERISTICS. Note 5:. Note 6:. TYPICAL PERFOR A CE …
File Format / SizePDF / 224 Kb
ELECTRICAL CHARACTERISTICS. Note 5:. Note 6:. TYPICAL PERFOR A CE CHARACTERISTICS. Dropout Voltage vs Load Current
ELECTRICAL CHARACTERISTICS Note 5: Note 6: TYPICAL PERFOR A CE CHARACTERISTICS Dropout Voltage vs Load Current
LTC3035
Operating conditions are limited by maximum junction
Note 6:
Dropout voltage is minimum input to output voltage differential temperature. The regulated output voltage specification will not apply for needed to maintain regulation at a specified output current. In dropout, the all possible combinations of input voltage and output current. When output voltage will be equal to VIN – VDROPOUT. operating at maximum input voltage, the output current range must be limited.
W U TYPICAL PERFOR A CE CHARACTERISTICS Dropout Voltage vs Load Current VIN Shutdown Current VIN No Load Operating Current
70 5.0 115 VOUT = 3.3V 4.5 60 110 TA = 125°C 4.0 50 3.5 105 T T A = 125°C A = 85°C 3.0 40 100 µA) µA) T 2.5 A = 25°C ( TA = 25°C 30 I IN I IN 95 2.0 TA = 85°C 20 1.5 90 DROPOUT VOLTAGE (mV) TA = 25°C T T A = –40°C 1.0 A = –40°C 10 85 0.5 TA = –40°C 0 0 80 0 50 100 150 200 250 300 0 1 2 3 4 5 6 3 3.5 4 4.5 5 5.5 6 I V OUT (mA) IN (V) VIN (V) 3035 G01 LT1108 • TPC12 3035 G03
V ADJ Voltage vs Temperature ADJ Voltage vs Input Voltage IN No Load Operating Current
120 404 404 VOUT = 1.5V VOUT = 3.3V VOUT = 1.5V 403 403 110 TA = 125°C TA = 85°C 402 402 100 401 401 µA) ( 90 T 400 400 A = 25°C I IN 399 399 80 TA = –40°C ADJ VOLTAGE (mV) ADJUST VOLTAGE (mV) 398 398 70 397 397 60 396 396 0 1 2 3 4 5 6 –45 –25 –5 15 35 55 75 95 115 0 1 2 3 4 5 6 VIN (V) TEMPERATURE (°C) VIN (V) 3035 G04 3035 G05 3035 G06 3035f 3
