LT1614 UUUPIN FUNCTIONSNFB (Pin 1): Negative Feedback Pin. Reference voltage is GND (Pin 4): Ground. Connect directly to local ground – 1.24V. Connect resistive divider tap here. The sug- plane. gested value for R2 is 24.9k. Set R1 and R2 according to: SW (Pin 5): Switch Pin. Minimize trace area at this pin to | V | – 1 2 . 4 keep EMI down. R OUT 1= 1 2.4 + V 4 5 . • 10–6 IN (Pin 6): Supply Pin. Must have 1µF ceramic bypass R2 capacitor right at the pin, connected directly to ground. LBI (Pin 7): Low-Battery Detector Input. 200mV refer- VC (Pin 2): Compensation Pin for Error Amplifier. Con- ence. Voltage on LBI must stay between ground and nect a series RC from this pin to ground. Typical values 700mV. Float this pin if not used. are 100kΩ and 1nF. Minimize trace area at VC. LBO (Pin 8): Low-Battery Detector Output. Open collec- SHDN (Pin 3): Shutdown. Ground this pin to turn off tor, can sink 10µA. A 1MΩ pull-up is recommended. Float switcher. Must be tied to VIN (or higher voltage) to enable this pin if not used. The low-battery detector is disabled switcher. Do not float the SHDN pin. when SHDN is low. LBO is high-Z in this state. WBLOCK DIAGRAM VIN 6 VIN R5 R6 40k 40k + SHDN VC SHUTDOWN 3 gm 2 – LBI ERROR + 7 + AMPLIFIER LBO Q1 Q2 A1 ×10 ENABLE 8 R3 BIAS – – A4 200mV 30k R4 140k COMPARATOR SW 1 – 5 DRIVER FF RAMP NFB V GENERATOR OUT + R Q Q3 + R1 Σ S (EXTERNAL) + A2 + NFB A = 3 0.15Ω R2 600kHz (EXTERNAL) OSCILLATOR – 4 GND 1614 BD Figure 2. Block Diagram 5
