Datasheet LT3487 (Analog Devices) - 3
DescriptionBoost and Inverting Switching Regulator for CCD Bias
Pages / Page16 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
File Format / SizePDF / 296 Kb
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
LT3487
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 3.6V, VBAT = 3.6V, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Schottky DP Forward Drop ISWP = 400mA 1045 mV Schottky DN Forward Drop ISWN = 600mA 980 mV Disconnect PNP VCE IVPOS = 50mA 205 mV Disconnect Current Limit VCAP = 15V, VPOS = 0V 100 155 mA VCAP – VBAT to Disconnect VBAT = 3.6V, VPOS = 0V, ICAP < 100µA 1.2 1.6 V Disconnect Leakage VBAT = 3.6V, CAP = 3.6V, VPOS = 0V 0.1 1.0 µA
Note 1:
Note 3:
Guaranteed by design, not directly tested. may cause permanent damage to the device. Exposure to any Absolute
Note 4:
Current fl ows out of pin. Maximum Rating condition for extended periods may affect device
Note 5:
Current limit guaranteed by design and/or correlation to static test. reliability and lifetime. Slope compensation reduces current limit at higher duty cycle.
Note 2:
The LT3487E is guaranteed to meet specifi ed performance from 0°C to 85°C. Specifi cations over the –40°C to 85°C operating range are assured by design, characterization and correlation with statistical process controls.
W U TYPICAL PERFOR A CE CHARACTERISTICS Shutdown Quiescent Current Positive Output to Enable Inverter FBP Voltage
10 100 1.300 8 90 µA) 1.275 6 80 (V) 1.250 FBPV 4 70 1.225 QUIESCENT CURRENT ( 2 60 PERCENTAGE OF FINAL FBP VOLTAGE (%) 0 50 1.200 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3487 G01 3487 G02 3487 G03 3487f 3
