Datasheet LTC1735 (Analog Devices) - 3
DescriptionHigh Efficiency Synchronous Step-Down Switching Regulator
Pages / Page32 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 415 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTC1735
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = 15V, VRUN/SS = 5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOVL Feedback Overvoltage Lockout ● 0.84 0.86 0.88 V IQ Input DC Supply Current (Note 4) Normal Mode 450 µA Shutdown VRUN/SS = 0V 15 25 µA VRUN/SS Run Pin Start Threshold VRUN/SS, Ramping Positive 1.0 1.5 1.9 V VRUN/SS Run Pin Begin Latchoff Threshold VRUN/SS, Ramping Positive 4.1 4.5 V IRUN/SS Soft-Start Charge Current VRUN/SS = 0V – 0.7 – 1.2 µA ISCL RUN/SS Discharge Current Soft Short Condition, VOSENSE = 0.5V, 0.5 2 4 µA VRUN/SS = 4.5V UVLO Undervoltage Lockout Measured at VIN Pin (VIN Ramping Down) ● 3.5 3.9 V ∆VSENSE(MAX) Maximum Current Sense Threshold VOSENSE = 0.7V ● 60 75 85 mV I – + SENSE Sense Pins Total Source Current VSENSE = VSENSE = 0V 60 80 µA tON(MIN) Minimum On-Time Tested with a Square Wave (Note 6) 160 200 ns TG Transition Time: (Note 7) TG tr Rise Time CLOAD = 3300pF 50 90 ns TG tf Fall Time CLOAD = 3300pF 50 90 ns BG Transition Time: (Note 7) BG tr Rise Time CLOAD = 3300pF 50 90 ns BG tf Fall Time CLOAD = 3300pF 40 80 ns TG/BG t1D Top Gate Off to Synchronous CLOAD = 3300pF Each Driver 100 ns Gate On Delay Time TG/BG t2D Synchronous Gate Off to Top CLOAD = 3300pF Each Driver 70 ns Gate On Delay Time
Internal VCC Regulator
VINTVCC Internal VCC Voltage 6V < VIN < 30V, VEXTVCC = 4V 5.0 5.2 5.4 V VLDO(INT) Internal VCC Load Regulation ICC = 0 to 20mA, VEXTVCC = 4V 0.2 1 % VLDO(EXT) EXTVCC Drop Voltage ICC = 20mA, VEXTVCC = 5V 130 200 mV VEXTVCC EXTVCC Switchover Voltage ICC = 20mA, EXTVCC Ramping Positive ● 4.5 4.7 V VEXTVCC(HYS) EXTVCC Hysteresis 0.2 V
Oscillator
fOSC Oscillator Frequency COSC = 43pF (Note 5) 265 300 335 kHz fH/fOSC Maximum Sync Frequency Ratio 1.3 fFCB(SYNC) FCB Pin Threshold For Sync Ramping Negative 0.9 1.2 V
PGOOD Output (LTC1735F Only)
VPGL PGOOD Voltage Low IPGOOD = 2mA 110 200 mV IPGOOD PGOOD Leakage Current VPGOOD = 5V ±1 µA VPG PGOOD Trip Level VOSENSE with Respect to Set Output Voltage VOSENSE Ramping Negative – 6.0 – 7.5 – 9.5 % VOSENSE Ramping Positive 6.0 7.5 9.5 %
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 2:
TJ is calculated from the ambient temperature TA and power of a device may be impaired. dissipation PD according to the following formulas: LTC1735CS, LTC1735IS: TJ = TA + (PD • 110 °C/W) LTC1735CGN, LTC1735IGN, LTC1735EGN: TJ = TA + (PD • 130°C/W) LTC1735CF, LTC1735IF: TJ = TA + (PD • 110°C/W) 1735fc 3
