Datasheet LTC3772 (Analog Devices) - 3
DescriptionMicropower No RSENSE Constant Frequency Step-Down DC/DC Controller
Pages / Page20 / 3 — ELECTRICAL CHARACTERISTICS The. indicates specifications which apply over …
File Format / SizePDF / 259 Kb
ELECTRICAL CHARACTERISTICS The. indicates specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The indicates specifications which apply over the full operating
LTC3772
indicates specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = 4.2V unless otherwise noted. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS
VFB Input Current (Note 5) –10 2 10 nA Overvoltage Protect Threshold Measured at VFB 0.850 0.880 0.910 V Overvoltage Protect Hysteresis 40 mV Oscillator Frequency Normal Operation VFB = 0.8V 500 550 650 kHz Output Short Circuit VFB = 0V 200 kHz Gate Drive Rise Time CLOAD = 3000pF 40 ns Gate Drive Fall Time CLOAD = 3000pF 40 ns Peak Current Sense Voltage IPRG = GND (Note 6) ● 90 105 120 mV IPRG = Floating ● 160 175 190 mV IPRG = VIN ● 228 245 262 mV Default Soft-Start Time 0.6 ms
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 4:
Dynamic supply current is higher due to the gate charge being of a device may be impaired. delivered at the switching frequency.
Note 2:
The LTC3772ETS8/LTC3772EDDB are guaranteed to meet
Note 5:
The LTC3772 are tested in a feedback loop that servos VFB to the specifications from 0°C to 70°C. Specifications over the –40°C to 85°C output of the error amplifier while maintaining ITH/RUN at the midpoint of operating temperature range are assured by design, characterization and the current limit range. correlation with statistical process controls.
Note 6:
Peak current sense voltage is reduced dependent on duty cycle as
Note 3:
TJ is calculated from the ambient temperature TA and power given in Figure 1. dissipation PD according to the following formula: TJ = TA + (PD • θJA°C/W)
W U TYPICAL PERFOR A CE CHARACTERISTICS Quiescent Current (No Load) Quiescent Current (No Load) Quiescent Current (Shutdown) vs Input Voltage vs Temperature vs Input Voltage
60 55 25 55 50 20 A) A) A) µ 50 µ 45 µ 45 15 40 40 35 35 10 30 QUIESCENT CURRENT ( 30 QUIESCENT CURRENT ( QUIESCENT CURRENT ( 5 25 25 20 20 0 2 3 4 5 6 7 8 9 10 –60 –40 –20 0 20 40 60 80 100 2 3 4 5 6 7 8 9 10 INPUT VOLTAGE (V) TEMPERATURE (°C) INPUT VOLTAGE (V) 3772 G01 3772 G02 3772 G03 3772f 3
