Datasheet LTC3778 (Analog Devices) - 3
DescriptionWide Operating Range, No RSENSE Step-Down Controller
Pages / Page24 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 312 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTC3778
denotes specifications which apply over the full operating temperature range, otherwise specifications are TA = 25
C. VIN = 15V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VRUN/SS(ON) RUN Pin Start Threshold ● 0.8 1.5 2 V VRUN/SS(LE) RUN Pin Latchoff Enable Threshold RUN/SS Pin Rising 4 4.5 V VRUN/SS(LT) RUN Pin Latchoff Threshold RUN/SS Pin Falling 3.5 4.2 V IRUN/SS(C) Soft-Start Charge Current – 0.5 – 1.2 –3 µA IRUN/SS(D) Soft-Start Discharge Current 0.8 1.8 3 µA VIN(UVLO) Undervoltage Lockout Threshold VIN Falling ● 3.4 3.9 V VIN(UVLOR) Undervoltage Lockout Threshold VIN Rising ● 3.5 4 V TG RUP TG Driver Pull-Up On Resistance TG High 2 3 Ω TG RDOWN TG Driver Pull-Down On Resistance TG Low 2 3 Ω BG RUP BG Driver Pull-Up On Resistance BG High 3 4 Ω BG RDOWN BG Driver Pull-Down On Resistance BG Low 1 2 Ω TG tr TG Rise Time CLOAD = 3300pF 20 ns TG tf TG Fall Time CLOAD = 3300pF 20 ns BG tr BG Rise Time CLOAD = 3300pF 20 ns BG tf BG Fall Time CLOAD = 3300pF 20 ns
Internal VCC Regulator
VINTVCC Internal VCC Voltage 6V < VIN < 30V, VEXTVCC = 4V ● 4.7 5 5.3 V ∆VLDO(LOADREG) Internal VCC Load Regulation ICC = 0mA to 20mA, VEXTVCC = 4V – 0.1 ±2 % VEXTVCC EXTVCC Switchover Voltage ICC = 20mA, VEXTVCC Rising ● 4.5 4.7 V ∆VEXTVCC EXTVCC Switch Drop Voltage ICC = 20mA, VEXTVCC = 5V 150 300 mV ∆VEXTVCC(HYS) EXTVCC Switchover Hysteresis 200 mV
PGOOD Output
∆VFBH PGOOD Upper Threshold VFB Rising 7.5 10 12.5 % ∆VFBL PGOOD Lower Threshold VFB Falling – 7.5 – 10 – 12.5 % ∆VFB(HYS) PGOOD Hysteresis VFB Returning 1 2.5 % VPGL PGOOD Low Voltage IPGOOD = 5mA 0.15 0.4 V
Note 1:
Absolute Maximum Ratings are those values beyond which the life of
Note 3:
The LTC3778 is tested in a feedback loop that adjusts VFB to achieve a device may be impaired. a specified error amplifier output voltage (ITH).
Note 2:
TJ is calculated from the ambient temperature TA and power
Note 4:
The LTC3778E is guaranteed to meet performance specifications from dissipation PD as follows: 0°C to 70°C. Specifications over the –40°C to 85°C operating temperature LTC3778E: T range are assured by design, characterization and correlation with statistical J = TA + (PD • 110°C/W) process controls. 3778f 3
