Datasheet LTC3809 (Analog Devices) - 3
DescriptionNo RSENSE , Low EMI, Synchronous DC/DC Controller
Pages / Page24 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 298 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC3809
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 4.2V unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loops
Input DC Supply Current (Note 4) Normal Operation 350 500 μA Sleep Mode 105 150 μA Shutdown RUN = 0V 9 20 μA UVLO VIN = UVLO Threshold – 200mV 3 10 μA Undervoltage Lockout Threshold (UVLO) VIN Falling l 1.95 2.25 2.55 V VIN Rising l 2.15 2.45 2.75 V Shutdown Threshold of RUN Pin 0.8 1.1 1.4 V Regulated Feedback Voltage (Note 5) l 0.591 0.6 0.609 V Output Voltage Line Regulation 2.75V < VIN < 9.8V (Note 5) 0.01 0.04 %/V Output Voltage Load Regulation ITH = 0.9V (Note 5) 0.1 0.5 % ITH = 1.7V –0.1 –0.5 % VFB Input Current (Note 5) 9 50 nA Overvoltage Protect Threshold Measured at VFB 0.66 0.68 0.7 V Overvoltage Protect Hysteresis 20 mV Auxiliary Feedback Threshold 0.325 0.4 0.475 V Top Gate (TG) Drive Rise Time CL = 3000pF 40 ns Top Gate (TG) Drive Fall Time CL = 3000pF 40 ns Bottom Gate (BG) Drive Rise Time CL = 3000pF 50 ns Bottom Gate (BG) Drive Fall Time CL = 3000pF 40 ns Maximum Current Sense Voltage (ΔV l SENSE(MAX)) IPRG = Floating (Note 6) 110 125 140 mV (V l IN – SW) IPRG = 0V (Note 6) 70 85 100 mV IPRG = VIN (Note 6) l 185 204 223 mV Soft-Start Time (Internal) Time for VFB to Ramp from 0.05V to 0.55V 0.5 0.74 0.9 ms
Oscillator and Phase-Locked Loop
Oscillator Frequency Unsynchronized (SYNC/MODE Not Clocked) PLLLPF = Floating 480 550 600 kHz PLLLPF = 0V 260 300 340 kHz PLLLPF = VIN 650 750 825 kHz Phase-Locked Loop Lock Range SYNC/MODE Clocked Minimum Synchronizable Frequency 200 250 kHz Maximum Synchronizible Frequency 750 1000 kHz Phase Detector Output Current Sinking fOSC > fSYNC/MODE –3 μA Sourcing fOSC < fSYNC/MODE 3 μA Spread Spectrum Frequency Range Minimum Switching Frequency 460 kHz Maximum Switching Frequency 635 kHz SYNC/MODE Pull-Down Current SYNC/MODE = 2.2V 2.6 μA
Note 1:
Note 3:
TJ is calculated from the ambient temperature TA and power may cause permanent damage to the device. Exposure to any Absolute dissipation PD according to the following formula: Maximum Rating condition for extended periods may affect device TJ = TA + (PD • θJA °C/W) reliability and lifetime.
Note 4:
Dynamic supply current is higher due to gate charge being
Note 2:
The LTC3809E is guaranteed to meet specifi ed performance from delivered at the switching frequency. 0°C to 85°C. Specifi cations over the –40°C to 85°C operating range are
Note 5:
The LTC3809 is tested in a feedback loop that servos ITH to a assured by design characterization, and correlation with statistical process specifi ed voltage and measures the resultant VFB voltage. controls.
Note 6:
Peak current sense voltage is reduced dependent on duty cycle to a percentage of value as shown in Figure 1. 3809fc 3
