Datasheet LTC3852 (Analog Devices) - 4
DescriptionLow Input Voltage, Synchronous Step-Down DC/DC Controller
Pages / Page32 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 429 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC3852
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C (Note 2), VIN1 = 3.3V, VIN2 = 15V, VRUN = 3.3V, SHDN = 0V, MODE/PLLIN = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Oscillator and Phase-Locked Loop (Step-Down Regulator)
fNOM1 Nominal Frequency RFREQ = 60k 460 500 540 kHz fLOW1 Lowest Frequency RFREQ = 160k 205 235 265 kHz fHIGH1 Highest Frequency RFREQ = 36k 690 750 810 kHz fNOM2 Nominal Frequency RFREQ = 60k (Note 7) 460 500 540 kHz fLOW2 Lowest Frequency RFREQ = 160k (Note 7) 205 235 265 kHz fHIGH2 Highest Frequency RFREQ = 36k (Note 7) 690 750 810 kHz fMODE MODE/PLLIN Minimum Input Frequency MODE/PLLIN = External Clock 250 kHz MODE/PLLIN Maximum Input Frequency 750 kHz RMODE/PLLIN MODE/PLLIN Input Resistance 100 kΩ IFREQ Phase Detector Output Current Sinking Capability fMODE > fOSC –90 μA Sourcing Capability fMODE < fOSC 75 μA
PGOOD Output
VPGL PGOOD Voltage Low IPGOOD = 2mA 0.1 0.3 V IPGOOD PGOOD Leakage Current VPGOOD = 5V ±1 μA VPG PGOOD Trip Level VFB with Respect to Regulated Voltage VFB Ramping Negative –12 –10 –8 % VFB Ramping Positive 8 10 12 %
VPUMP Charge Pump Supply (VIN1 = 3.3V; VSHDN = 3.3V, VRUN = 0); CVIN1 = 4.7μF, CFLY = 2.2μF, CVPUMP = 4.7μF
VIN1 Input Voltage Range 2.7 5.5 V VPUMP Charge Pump Doubler Output Voltage CFLY = 2.2μF 2.7V < VIN1 < 5.5V; IVPUMP = 1mA l 4.8 5.05 5.3 V ISHDN Shutdown Pin Current SHDN = 0V; VPUMP = 0V 1 μA VRIPPLE Output Ripple at VPUMP IVPUMP = 50mA (Note 10) 20 mVP-P fPUMP Charge Pump Frequency 0.6 1.2 1.8 MHz VIH SHDN Input Threshold l 1.3 V VIL SHDN Input Threshold l 0.4 V IIH SHDN Input Current –1 1 μA IIL SHDN Input Current –1 1 μA ROL Effective Open-Loop Output Resistance VIN1 = 2.7V, VPUMP = 4.5V 6 Ω (Note 8)
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings may
Note 5:
Rise and fall times are measured using 10% and 90% levels. Delay cause permanent damage to the device. Exposure to any Absolute Maximum times are measured using 50% levels. Rise and fall times are assured by Rating condition for extended periods may affect device reliability and lifetime. design, characterization and correlation with statistical process controls.
Note 2:
The LTC3852 is tested under pulsed load conditions such that
Note 6:
The minimum on-time condition is specifi ed for an inductor TJ ≈ TA. The LTC3852E is guaranteed to meet specifi cations from peak-to-peak ripple current equal to 40% of IMAX (see Minimum On-Time 0°C to 85°C junction temperature. Specifi cations over the –40°C to Considerations in the Applications Information Section). 125°C operating junction temperature range are assured by design,
Note 7:
VIN1 = 3.3V; Connect VPUMP, VIN2 and INTVCC together. characterization and correlation with statistical process controls. The
Note 8:
ROL = (2VIN - VOUT)/IOUT LTC3852I is guaranteed over the –40°C to 125°C operating junction
Note 9:
V temperature range. T IN2 swept while not connected to VPUMP or INTVCC. J is calculated from the ambient temperature, TA and power dissipation P
Note 10:
Guaranteed by design, not tested in production. D according to the following formula: TJ = TA + (PD • 38°C/W)
Note 3:
The LTC3852 is tested in a feedback loop that servos VITH to a specifi ed voltage and measures the resultant VFB.
Note 4:
Dynamic supply current is higher due to the gate charge being delivered at the switching frequency. See Applications information. 3852f 4
