LTC2945 ORDER INFORMATION LEAD FREE FINISHTAPE AND REELPART MARKINGPACKAGE DESCRIPTIONTEMPERATURE RANGE LTC2945CUD#PBF LTC2945CUD#TRPBF LFWK 12-Lead (3mm × 3mm) Plastic QFN 0°C to 70°C LTC2945IUD#PBF LTC2945IUD#TRPBF LFWK 12-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C LTC2945HUD#PBF LTC2945HUD#TRPBF LFWK 12-Lead (3mm × 3mm) Plastic QFN –40°C to 125°C LTC2945CUD-1#PBF LTC2945CUD-1#TRPBF LFYX 12-Lead (3mm × 3mm) Plastic QFN 0°C to 70°C LTC2945IUD-1#PBF LTC2945IUD-1#TRPBF LFYX 12-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C LTC2945HUD-1#PBF LTC2945HUD-1#TRPBF LFYX 12-Lead (3mm × 3mm) Plastic QFN –40°C to 125°C LTC2945CMS#PBF LTC2945CMS#TRPBF 2945 12-Lead Plastic MSOP 0°C to 70°C LTC2945IMS#PBF LTC2945IMS#TRPBF 2945 12-Lead Plastic MSOP –40°C to 85°C LTC2945HMS#PBF LTC2945HMS#TRPBF 2945 12-Lead Plastic MSOP –40°C to 125°C LTC2945CMS-1#PBF LTC2945CMS-1#TRPBF 29451 12-Lead Plastic MSOP 0°C to 70°C LTC2945IMS-1#PBF LTC2945IMS-1#TRPBF 29451 12-Lead Plastic MSOP –40°C to 85°C LTC2945HMS-1#PBF LTC2945HMS-1#TRPBF 29451 12-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ ELECTRICAL CHARACTERISTICSThe l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TA = 25°C. VDD is from 4V to 80V unless otherwise noted. (Note 2) SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITSSUPPLIES VDD VDD Supply Voltage Range l 4 80 V VINTVCC INTVCC Supply Voltage Range l 2.7 5.9 V IDD VDD Supply Current VDD = 48V, INTVCC Open l 0.8 1.2 mA Shutdown l 40 70 µA ICC INTVCC Supply Current INTVCC = VDD = 5V l 0.6 0.9 mA Shutdown, INTVCC = VDD = 5V l 20 80 µA ICCSRC INTVCC Linear Regulator Output Current VDD = 7V l –10 mA VCC INTVCC Linear Regulator Voltage 7V < VDD < 80V, ILOAD = 1mA (C-, I-Grade) l 4.5 5 5.5 V 7V < VDD < 80V, ILOAD = 1mA (H-Grade) l 4.5 5 5.7 V ΔVCC INTVCC Linear Regulator Load Regulation 7V < VDD < 80V, ILOAD = 1mA to 10mA l 100 200 mV VCCZ INTVCC Shunt Regulator Voltage VDD = 48V, ICC = 1mA l 5.9 6.3 6.7 V ΔVCCZ INTVCC Shunt Regulator Load Regulation VDD = 48V, ICC = 1mA to 35mA l 250 mV VCC(UVL) INTVCC Supply Undervoltage Lockout INTVCC Rising, VDD = INTVCC l 2.2 2.6 2.69 V VDD(UVL) VDD Supply Undervoltage Lockout VDD Rising, INTVCC Open (C-, I-Grade) l 2.9 3.2 3.5 V VDD Rising, INTVCC Open (H-Grade) l 2.6 3.2 3.5 V VDDI2C(RST) VDD I2C Logic Reset VDD Falling, INTVCC Open (C-, I-Grade) l 2 2.5 V VDD Falling, INTVCC Open (H-Grade) l 1.7 2.5 V VCCI2C(RST) INTVCC I2C Logic Reset INTVCC Falling, VDD = INTVCC l 1.5 1.8 V 2945fb For more information www.linear.com/LTC2945 3
