Datasheet AD4001, AD4005 (Analog Devices) - 3
Description16-Bit, 1 MSPS, Precision, Differential SAR ADC
Pages / Page37 / 3 — Data Sheet. AD4001/AD4005. 1/2017—Revision 0: Initial Version
File Format / SizePDF / 920 Kb
Data Sheet AD4001/AD4005 1/2017—Revision 0: Initial Version
Changes to Layout Guidelines Section and Evaluating the AD4001/AD4005 Performance Section ... 34 Updated Outline Dimensions .. 35 Changes to Ordering Guide ... 35
Rev. B | Page 3 of 37 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Transfer Functions Applications Information Typical Application Diagrams Analog Inputs Input Overvoltage Clamp Circuit Differential Input Considerations Switched Capacitor Input RC Filter Values Driver Amplifier Choice Single to Differential Driver High Frequency Input Signals Multiplexed Applications Ease of Drive Features Input Span Compression High-Z Mode Long Acquisition Phase Voltage Reference Input Power Supply Digital Interface Register Read/Write Functionality Status Word /CS Mode, 3-Wire Turbo Mode /CS Mode, 3-Wire Without Busy Indicator /CS Mode, 3-Wire with Busy Indicator /CS Mode, 4-Wire Turbo Mode /CS Mode, 4-Wire Without Busy Indicator /CS Mode, 4-Wire with Busy Indicator Daisy-Chain Mode Layout Guidelines Evaluating the AD4001/AD4005 Performance Outline Dimensions Ordering Guide
