Datasheet AD4001, AD4005 (Analog Devices) - 9
Description16-Bit, 1 MSPS, Precision, Differential SAR ADC
Pages / Page37 / 9 — Data Sheet. AD4001/AD4005. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. …
File Format / SizePDF / 920 Kb
Data Sheet. AD4001/AD4005. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 5. Parameter. Rating. Table 6. Thermal Resistance
Data Sheet AD4001/AD4005 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 5 Parameter Rating Table 6 Thermal Resistance
link to page 20 link to page 37
Note that the input overvoltage clamp cannot sustain the
THERMAL RESISTANCE
overvoltage condition for an indefinite amount of time. Thermal performance is directly linked to printed circuit board
Table 5.
(PCB) design and operating environment. Careful attention to
Parameter Rating
PCB thermal design is required. Analog Inputs
IN+, IN− to GND1 −0.3 V to VREF + 0.4 V
Package Type1 θ 2 θ 3 Unit
or ±50 mA
JA JC
RM-10 147 38 °C/W Supply Voltage CP-10-9 114 33 °C/W REF, VIO to GND −0.3 V to +6.0 V VDD to GND −0.3 V to +2.1 V 1 Test Condition 1: thermal impedance simulated values are based upon use VDD to VIO −6 V to +2.4 V of 2S2P JEDEC PCB. See the Ordering Guide. 2 θ Digital Inputs to GND −0.3 V to VIO + 0.3 V JA is the natural convection junction-to-ambient thermal resistance measured in a one cubic foot sealed enclosure. Digital Outputs to GND −0.3 V to VIO + 0.3 V 3 θJC is the junction-to-case thermal resistance. Storage Temperature Range −65°C to +150°C Junction Temperature 150°C
ESD CAUTION
Lead Temperature Soldering 260°C reflow as per JEDEC J-STD-020 ESD Ratings Human Body Model 4 kV Machine Model 200 V Field Induced Charged Device Model 1.25 kV 1 See the Analog Inputs section for an explanation of IN+ and IN−. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. B | Page 9 of 37 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Transfer Functions Applications Information Typical Application Diagrams Analog Inputs Input Overvoltage Clamp Circuit Differential Input Considerations Switched Capacitor Input RC Filter Values Driver Amplifier Choice Single to Differential Driver High Frequency Input Signals Multiplexed Applications Ease of Drive Features Input Span Compression High-Z Mode Long Acquisition Phase Voltage Reference Input Power Supply Digital Interface Register Read/Write Functionality Status Word /CS Mode, 3-Wire Turbo Mode /CS Mode, 3-Wire Without Busy Indicator /CS Mode, 3-Wire with Busy Indicator /CS Mode, 4-Wire Turbo Mode /CS Mode, 4-Wire Without Busy Indicator /CS Mode, 4-Wire with Busy Indicator Daisy-Chain Mode Layout Guidelines Evaluating the AD4001/AD4005 Performance Outline Dimensions Ordering Guide
