Datasheet HMCAD5831LP9BE (Analog Devices) - 3
Description26 GS/s 3-Bit Analog-to-Digital Converter w/ Overrange, Inhibit, and 1:2 DEMUX
Pages / Page15 / 3 — HMCAD5831LP9BE. 3-BIT 26 GSPS ANALOG-TO-DIGITAL. CONVERTER W/ OVERRANGE, …
File Format / SizePDF / 939 Kb
HMCAD5831LP9BE. 3-BIT 26 GSPS ANALOG-TO-DIGITAL. CONVERTER W/ OVERRANGE, INHIBIT, AND 1:2 DEMUX. Electrical Specifications
HMCAD5831LP9BE 3-BIT 26 GSPS ANALOG-TO-DIGITAL CONVERTER W/ OVERRANGE, INHIBIT, AND 1:2 DEMUX Electrical Specifications
HMCAD5831LP9BE
v02.0713
(continued) Parameter Conditions Min. typ. Max Units Clock, Xor rin Differential 100 Ω t Ladder top voltage (rtF) Can be user defined -0.808 v M Ladder Bottom voltage (rBF) [4] Can be user defined -1.064 v s output amplitude [5] single ended, peak to peak 286 mvp-p output High voltage [5] -33 mv s - output Low voltage [5] -319 mv r Xor Clock rate 156.25 MHz e Xor Input Power, single ended -3 dBm t Data Inhibit rin single ended 600 Ω r Data Inhibit High voltage 200 mv e v Data Inhibit Low voltage -200 mv n Data, Clock, ovr Bits rout Differential 100 Ω o Data, Clock, ovr Bits rout single ended 50 Ω Demux ratio 1:2 enoB (20 GsPs) fin = 312.5 MHz 2.9 bits enoB (20 GsPs) fin = 9.6875 GHz 2.9 bits ata C enoB (20 GsPs) fin = 19.6875 GHz 2.9 bits D enoB (26 GsPs) fin = 406.25 MHz 2.9 bits enoB (26 GsPs) fin = 12.5938 GHz 2.9 bits sFDr (20 GsPs) fin = 312.5 MHz 24.7 dBFs sFDr (20 GsPs) fin = 9.6875 GHz 25.7 dBFs sFDr (20 GsPs) fin = 19.6875 GHz 27.2 dBFs Power supply Current (-5v) 725 ma Power supply Current (-3.3v) 176 ma Power Independent of clock rate 4.2 W [1] see application Information section for operation over range of temperatures. [2] requires sufficient clock power and cooling. [3] Input signal common mode nominally should be set to this point, but may be adjusted with rtF/rBF. see application Information section. [4] see application Information section for guidance on setting reference voltages. [5] With a single 200 Ω resistor tied from vreF1 and vreF2 to oGnD. vreF1 and vreF2 are connected off chip. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
2
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 pp3li o ca rti a o pp n Susp@h portitti : P te ho .c neom : 1-800-ANALOG-D
