Datasheet AD7903 (Analog Devices) - 7
DescriptionDual Differential 16-Bit, 1 MSPS PulSAR 12.0 mW in QSOP
Pages / Page29 / 7 — AD7903. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter Rating. …
AD7903. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 5. Parameter Rating. ESD CAUTION
AD7903 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating ESD CAUTION
link to page 16
AD7903 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress Analog Inputs rating only; functional operation of the device at these or any INx+, INx− to GND1 −0.3 V to V other conditions above those indicated in the operational REF + 0.3 V or ±10 mA Supply Voltage section of this specification is not implied. Exposure to absolute REFx, VIOx to GND −0.3 V to +6.0 V maximum rating conditions for extended periods may affect VDDx to GND −0.3 V to +3.0 V device reliability. VDDx to VIOx +3 V to −6 V
ESD CAUTION
Digital Inputs to GND −0.3 V to VIO + 0.3 V Digital Outputs to GND −0.3 V to VIO + 0.3 V Storage Temperature Range −65°C to +150°C Junction Temperature 150°C Lead Temperatures Vapor Phase (60 sec) 255°C Infrared (15 sec) 260°C 1 See the Analog Inputs section for an explanation of INx+ and INx−. Rev. B | Page 6 of 28 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Transfer Functions Typical Connection Diagram Analog Inputs Driver Amplifier Choice Single-to-Differential Driver Voltage Reference Input Power Supply Digital Interface CS Mode CS Mode, 3-Wire Interface Without Busy Indicator CS Mode, 3-Wire Interface with Busy Indicator CS Mode, 4-Wire Interface Without Busy Indicator CS Mode, 4-Wire Interface with Busy Indicator Chain Mode Chain Mode Without Busy Indicator Chain Mode with Busy Indicator Applications Information Simultaneous Sampling Functional Safety Considerations Layout Evaluating Performance of the AD7903 Outline Dimensions Ordering Guide
