Datasheet AD9257 (Analog Devices) - 3
DescriptionOctal, 14-Bit, 40/65 MSPS Serial LVDS 1.8 V A/D Converter
Pages / Page41 / 3 — AD9257. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 4/13—Rev. 0 to …
RevisionA
AD9257. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 4/13—Rev. 0 to Rev. A. 10/11—Revision 0: Initial Version
AD9257 Data Sheet TABLE OF CONTENTS REVISION HISTORY 4/13—Rev 0 to Rev A 10/11—Revision 0: Initial Version
link to page 1 link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 4 link to page 5 link to page 6 link to page 7 link to page 7 link to page 9 link to page 9 link to page 9 link to page 10 link to page 12 link to page 18 link to page 19 link to page 19 link to page 20 link to page 21 link to page 23 link to page 24 link to page 28 link to page 28 link to page 29 link to page 29 link to page 30 link to page 30 link to page 30 link to page 31 link to page 31 link to page 32 link to page 35 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 38 link to page 38 link to page 12 link to page 15
Features .. 1 Power Dissipation and Power-Down Mode ... 22 Applications ... 1 Digital Outputs and Timing ... 23 General Description ... 1 Built-In Output Test Modes .. 27 Functional Block Diagram .. 1 Output Test Modes ... 27 Product Highlights ... 1 Serial Port Interface (SPI) .. 28 Revision History ... 2 Configuration Using the SPI ... 28 Specifications ... 3 Hardware Interface ... 29 DC Specifications ... 3 Configuration Without the SPI .. 29 AC Specifications .. 4 SPI Accessible Features .. 29 Digital Specifications ... 5 Memory Map .. 30 Switching Specifications .. 6 Reading the Memory Map Register Table ... 30 Timing Specifications .. 6 Memory Map Register Table ... 31 Absolute Maximum Ratings .. 8 Memory Map Register Descriptions .. 34 Thermal Characteristics .. 8 Applications Information .. 36 ESD Caution .. 8 Design Guidelines .. 36 Pin Configuration and Function Descriptions ... 9 Power and Ground Recommendations ... 36 Typical Performance Characteristics ... 11 Clock Stability Considerations ... 36 AD9257-65 .. 11 Exposed Pad Thermal Heat Slug Recommendations .. 36 AD9257-40 .. 14 VCM ... 36 Equivalent Circuits ... 17 Reference Decoupling .. 36 Theory of Operation .. 18 SPI Port .. 36 Analog Input Considerations .. 18 Outline Dimensions ... 37 Voltage Reference ... 19 Ordering Guide .. 37 Clock Input Considerations .. 20
REVISION HISTORY 4/13—Rev. 0 to Rev. A 10/11—Revision 0: Initial Version
Changes to Table 1 .. 3 Changes to AC Specifications Section ... 4 Added Propagation Delay of 1.5 ns Min and 3.1 ns Max; Table 4 .. 6 Added CLK Divider = 8 to Figure 7, Figure 9, Figure 10, and Figure 11 Captions .. 11 Changes to Figure 14 and Figure 17 ... 12 Added CLK Divider = 8 to Figure 22, Figure 24, and Figure 25 Captions ... 14 Added CLK Divider = 4 to Figure 28 and Figure 31; Changes to Figure 32 .. 15 Changes to Figure 36 and Figure 37 ... 17 Changes to Figure 56 .. 22 Changes to Digital Outputs and Timing Section ... 23 Changes to Channel Specific Registers Section .. 30 Changes to Register 0x21, Bit 3; Table 17 .. 33 Changes to Bits[6:4]—Input Clock Phase Adjust Section... 35 Added Clock Stability Considerations Section ... 36 Updated Outline Dimensions ... 37 Rev. A | Page 2 of 40 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics AD9257-65 AD9257-40 Equivalent Circuits Theory of Operation Analog Input Considerations Input Common Mode Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO/DFS Pin SCLK/DTP Pin CSB Pin RBIAS Pin Built-In Output Test Modes Output Test Modes Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Channel-Specific Registers Memory Map Register Table Memory Map Register Descriptions Device Index (Register 0x04 and Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Bits[7:6]—Open Bits[1:0]—Internal Power-Down Mode Enhancement Control (Register 0x0C) Bits[7:3]—Open Bit 2—Chop Mode Bits[1:0]—Open Output Mode (Register 0x14) Bit 7—Open Bit 6—LVDS-ANSI/LVDS-IEEE Option Bits[5:3]—Open Bit 2—Output Invert Bit 1—Open Bit 0—Output Format Output Adjust (Register 0x15) Bits[7:6]—Open Bits[5:4]—Output Termination Bits[3:1]—Open Bit 0—Output Drive Output Phase (Register 0x16) Bit 7—Open Bits[6:4]—Input Clock Phase Adjust Bits[3:0]—Output Clock Phase Adjust Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) Bits[7:1]—Open Bit 0—SDIO Pull-Down User I/O Control 3 (Register 0x102) Bits[7:4]—Open Bit 3—VCM Power-Down Bits[2:0]—Open Applications Information Design Guidelines Power and Ground Recommendations Clock Stability Considerations Exposed Pad Thermal Heat Slug Recommendations VCM Reference Decoupling SPI Port Outline Dimensions Ordering Guide
