Datasheet AD9434 (Analog Devices) - 8 Manufacturer Analog Devices Description 12-Bit, 370 MSPS/500 MSPS, 1.8 V Analog-to-Digital Converter Pages / Page 29 / 8 — Data Sheet. AD9434. Timing Diagrams. N – 1. N + 4. N + 5. N + 3. VIN+, … Revision B File Format / Size PDF / 937 Kb Document Language English
Data Sheet. AD9434. Timing Diagrams. N – 1. N + 4. N + 5. N + 3. VIN+, VIN–. N + 1. N + 2. tCH. tCL. 1/fS. CLK+. CLK–. tCPD. DCO+. DCO–. tSKEW. tPD. Dx+. N – 15
Model Line for this Datasheet Text Version of Document Data Sheet AD9434 Timing Diagrams N – 1 t N + 4 A N + 5 N N + 3 VIN+, VIN– N + 1 N + 2 tCH tCL 1/fS CLK+ CLK– tCPD DCO+ DCO– tSKEW tPD Dx+ N – 15 N – 14 N – 13 N – 12 N – 11 Dx– -002 383 09 Figure 2. Single Data Rate ModeN – 1 t N + 4 A N + 5 N N + 3 VIN+, VIN– N + 1 N + 2 tCH tCL 1/fS CLK+ CLK– tCPD DCO+ DCO– tSKEW tPD D0/D6+ D6 D0 D6 D0 D6 D0 D6 D0 D6 D0 N – 15 N – 14 N – 14 N – 13 N – 13 N – 12 N – 12 N – 11 N – 11 N – 10 D0/D6– D5/D11+ D11 D5 D11 D5 D11 D5 D11 D5 D11 D5 N – 15 N – 14 N – 14 N – 13 N – 13 N – 12 N – 12 N – 11 N – 11 N – 10 D5/D11– 6 MSBs 03 06 LSBs 9383- 0 Figure 3. Double Data Rate Mode Rev. B | Page 7 of 28 Document Outline Features Applications General Description Functional Block Diagram Product Highlights Revision History Specifications DC Specifications AC Specifications Digital Specifications Switching Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation Analog Input and Voltage Reference Differential Input Configurations Clock Input Considerations Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs Digital Outputs and Timing Output Data Rate and Pinout Configuration Out-of-Range (OR) Timing VREF AD9434 Configuration Using the SPI Using the AD9434 to Replace the AD9230 Hardware Interface Configuration Without the SPI Memory Map Reading the Memory Map Table Reserved Locations Default Values Logic Levels Outline Dimensions Ordering Guide
