Datasheet HMCAD1511 (Analog Devices) - 4
DescriptionHigh Speed Multi-Mode 8-Bit 1 GSPS A/D Converter
Pages / Page31 / 4 — HMCAD1511. HigH Speed Multi-Mode 8-Bit. 30 MSpS to 1 gSpS A/d Converter. …
HMCAD1511. HigH Speed Multi-Mode 8-Bit. 30 MSpS to 1 gSpS A/d Converter. AC Specifications. Parameter. Description. Min. Typ. Max. Unit
HMCAD1511 HigH Speed Multi-Mode 8-Bit 30 MSpS to 1 gSpS A/d Converter AC Specifications Parameter Description Min Typ Max Unit
HMCAD1511
v04.1015
AvDD = 1.8v, DvDD = 1.8v, ovDD = 1.8v, 50% clock duty cycle, -1 dBFs 71 MHz input signal, Gain = 1X, rsDs output data levels unless otherwise noted
Parameter Description Min Typ Max Unit Performance
snr signal to noise ratio, excluding interleaving spurs single Ch Mode, F = 1000 MsPs 48.5 49.8 dBFs s single Ch Mode, F = 1000 MsPs, F = 170 MHz 49.7 dBFs s In single Ch Mode, F = 1000 MsPs, Gain = 10X 48.1 dBFs s single Ch Mode, F = 500 MsPs 48.5 49.8 dBFs s single Ch Mode, F = 500 MsPs, Gain = 10X 48.2 dBFs s Dual Ch Mode, F = 500 MsPs 48.5 49.8 dBFs s Quad Ch Mode, F = 250 MsPs 48.5 49.9 dBFs s 0 signal to noise and Distortion ratio, including interleaving sInADincl spurs single Ch Mode, F = 1000 MsPs 45.7 dBFs s Dual Ch Mode, F = 500 MsPs 44 dBFs s Quad Ch Mode, F = 250 MsPs 49.2 dBFs t s signal to noise and Distortion ratio, excluding interleaving sInAD M excl spurs s single Ch Mode, F = 1000 MsPs 48 49.3 dBFs s single Ch Mode, F = 1000 MsPs, F = 170 MHz 46.5 dBFs s In single Ch Mode, F = 1000 MsPs, Gain = 10X 47.5 dBFs s s - single Ch Mode, F = 500 MsPs 48 49.4 dBFs s r single Ch Mode, F = 500 MsPs, Gain = 10X 47.7 dBFs s e Dual Ch Mode, F = 500 MsPs 48 49 dBFs s t Quad Ch Mode, F = 250 MsPs 48 49.3 dBFs s r sFDr spurious Free Dynamic range, including interleaving spurs incl single Ch Mode, F = 1000 MsPs 49 dBc e s Dual Ch Mode, F = 500 MsPs 44 dBc v s Quad Ch Mode, F = 250 MsPs 57 dBc s n sFDr spurious Free Dynamic range, excluding interleaving spurs excl o single Ch Mode, F = 1000 MsPs 55 64 dBc s single Ch Mode, F = 1000 MsPs, F = 170 MHz 63 dBc s In single Ch Mode, F = 1000 MsPs, Gain = 10X 62 dBc s single Ch Mode, F = 500 MsPs 56 65 dBc s /D C single Ch Mode, F = 500 MsPs, Gain = 10X 65 dBc s A Dual Ch Mode, F = 500 MsPs 55 63 dBc s Quad Ch Mode, F = 250 MsPs 58 70 dBc s HD2/3 Worst of HD2/HD3 single Ch Mode, F = 1000 MsPs 60 65 dBc s single Ch Mode, F = 1000 MsPs, F = 170 MHz 65 dBc s In single Ch Mode, F = 1000 MsPs, Gain = 10X 63 dBc s single Ch Mode, F = 500 MsPs 60 65 dBc s single Ch Mode, F = 500 MsPs, Gain = 10X 65 dBc s Dual Ch Mode, F = 500 MsPs 57 63 dBc s Quad Ch Mode, F = 250 MsPs 50 70 dBc s enoB effective number of Bits, excluding interleaving spurs excl single Ch Mode, F = 1000 MsPs 7.9 bits s single Ch Mode, F = 1000 MsPs, F = 170 MHz 7.4 bits s In single Ch Mode, F = 1000 MsPs, Gain = 10X 7.6 bits s single Ch Mode, F = 500 MsPs 7.9 bits s single Ch Mode, F = 500 MsPs, Gain = 10X 7.6 bits s Dual Ch Mode, F = 500 MsPs 7.8 bits s Quad Ch Mode, F = 250 MsPs 7.9 bits s Informatio For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, n furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringement MA 02062-9106 s of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
0 - 3
rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise Phone: 781-329-4700 • Order online at www.analog.com Phone: 781-329-4700 • Order online at www.analog.com under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Application Support: Phone: 1-800-ANALOG-D
