Datasheet HMCAD1511 (Analog Devices) - 8
DescriptionHigh Speed Multi-Mode 8-Bit 1 GSPS A/D Converter
Pages / Page31 / 8 — HMCAD1511. HigH Speed Multi-Mode 8-Bit. 30 MSpS to 1 gSpS A/d Converter. …
HMCAD1511. HigH Speed Multi-Mode 8-Bit. 30 MSpS to 1 gSpS A/d Converter. table 3: pin descriptions. Pin Name. Description
HMCAD1511 HigH Speed Multi-Mode 8-Bit 30 MSpS to 1 gSpS A/d Converter table 3: pin descriptions Pin Name Description
HMCAD1511
v04.1015
HigH Speed Multi-Mode 8-Bit 30 MSpS to 1 gSpS A/d Converter table 3: pin descriptions Pin Name Description Pin Number # Of Pins
FCLKP LvDs frame clock (1X), positive output 19 1 FCLKn LvDs frame clock (1X), negative output 20 1 DP3A LvDs channel 3A, positive output 21 1 Dn3A LvDs channel 3A, negative output 22 1 DP3B LvDs channel 3B, positive output 23 1 Dn3B LvDs channel 3B, negative output 24 1 DP4A LvDs channel 4A, positive output 25 1 Dn4A LvDs channel 4A, negative output 26 1 DP4B LvDs channel 4B, positive output 27 1 Dn4B LvDs channel 4B, negative output 28 1 0 Avss2 Analog ground domain 2 31 1 AvDD2 Analog power supply domain 2, 1.8v 32 1 ovDD Digital CMos Inputs supply voltage 33 1 CLKn negative differential input clock. 34 1 t CLKP Positive differential input clock 35 1 M In4 negative differential input signal, channel 4 37 1 s IP4 Positive differential input signal, channel 4 38 1 Avss Analog ground 39, 42, 45 3 s - In3 negative differential input signal, channel 3 40 1 r IP3 Positive differential input signal, channel 3 41 1 e In2 negative differential input signal, channel 2 43 1 t IP2 Positive differential input signal, channel 2 44 1 r In1 negative differential input signal, channel 1 46 1 e IP1 Positive differential input signal, channel 1 47 1 v vCM Common mode output pin, 0.5*AvDD 48 1 n o /D C A Informatio For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, n furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringement MA 02062-9106 s of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
0 - 7
rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise Phone: 781-329-4700 • Order online at www.analog.com under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Application Support: Phone: 1-800-ANALOG-D
