Datasheet AD9255 (Analog Devices) - 2
Description14-Bit, 125 MSPS/105 MSPS/80 MSPS, 1.8 V Analog-to-Digital Converter
Pages / Page45 / 2 — AD9255* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionC
AD9255* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9255* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9255 IBIS Models
EVALUATION KITS
• AD9255/AD9265 S-Parameters • AD9255 Evaluation Board
REFERENCE MATERIALS DOCUMENTATION Technical Articles Application Notes
• Improve The Design Of Your Passive Wideband ADC • AN-586: LVDS Outputs for High Speed A/D Converters Front-End Network • AN-742: Frequency Domain Response of Switched- • MS-2210: Designing Power Supplies for High Speed ADC Capacitor ADCs • AN-807: Multicarrier WCDMA Feasibility
DESIGN RESOURCES
• AN-808: Multicarrier CDMA2000 Feasibility • AD9255 Material Declaration • AN-812: MicroController-Based Serial Port Interface (SPI) • PCN-PDN Information Boot Circuit • Quality And Reliability • AN-827: A Resonant Approach to Interfacing Amplifiers to • Symbols and Footprints Switched-Capacitor ADCs • AN-878: High Speed ADC SPI Control Software
DISCUSSIONS
• AN-935: Designing an ADC Transformer-Coupled Front View all AD9255 EngineerZone Discussions. End
Data Sheet SAMPLE AND BUY
• AD9255: 14-Bit, 125 MSPS/105 MSPS/80 MSPS, 1.8 V Analog-to-Digital Converter Data Sheet Visit the product page to see pricing options.
User Guides TECHNICAL SUPPORT
• UG-074: Evaluating the AD9265/AD9255 Analog-to- Digital Converters Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications Product Highlights Functional Block Diagram Table of Contents Revision History General Description Specifications ADC DC Specifications ADC AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation ADC Architecture Analog Input Considerations Input Common Mode Dither Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Clock Duty Cycle Input Clock Divider Jitter Considerations Power Dissipation and Standby Mode Digital Outputs Digital Output Enable Function (OEB) Timing Data Clock Output (DCO) Built-In Self-Test (BIST) and Output Test Built-In Self-Test (BIST) Output Test Modes Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Transfer Register Map Memory Map Register Table Memory Map Register Descriptions Sync Control (Register 0x100) Applications Information Design Guidelines Power and Ground Recommendations LVDS Operation Exposed Paddle Thermal Heat Slug Recommendations VCM RBIAS Reference Decoupling SPI Port Outline Dimensions Ordering Guide
