Datasheet AD9255 (Analog Devices) - 9
Description14-Bit, 125 MSPS/105 MSPS/80 MSPS, 1.8 V Analog-to-Digital Converter
Pages / Page45 / 9 — AD9255. Data Sheet. SWITCHING SPECIFICATIONS. Table 4. AD9255BCPZ-801 …
RevisionC
AD9255. Data Sheet. SWITCHING SPECIFICATIONS. Table 4. AD9255BCPZ-801 AD92. 55BCPZ-1051 AD9255BC. PZ-1251. Parameter
AD9255 Data Sheet SWITCHING SPECIFICATIONS Table 4 AD9255BCPZ-801 AD92 55BCPZ-1051 AD9255BC PZ-1251 Parameter
link to page 42 link to page 31 link to page 38 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9
AVDD = 1.8 V, DRVDD = 1.8 V, SVDD = 1.8 V, maximum sample rate, VIN = −1.0 dBFS differential input, 1.0 V internal reference, and DCS enabled, unless otherwise noted.
Table 4. AD9255BCPZ-801 AD92 55BCPZ-1051 AD9255BC PZ-1251 Parameter Temp Min Typ Max Min Typ Max Min Typ Max Unit
CLOCK INPUT PARAMETERS Input Clock Rate Full 625 625 625 MHz Conversion Rate2 DCS Enabled Full 20 80 20 105 20 125 MSPS DCS Disabled Full 10 80 10 105 10 125 MSPS CLK Period—Divide-by-1 Mode (tCLK) Full 12.5 9.5 8 ns CLK Pulse Width High (tCH) Divide-by-1 Mode DCS Enabled Full 3.75 6.25 8.75 2.85 4.75 6.65 2.4 4 5.6 ns DCS Disabled 5.9 6.25 6.6 4.5 4.75 5.0 3.8 4 4.2 ns Divide-by-3 Mode, Divide-by-5 Mode, and Full 0.8 0.8 0.8 ns Divide-by-7 Mode, DCS Enabled3 Divide-by-2 Mode, Divide-by-4 Mode, Divide- Full 0.8 0.8 0.8 ns by-6 Mode, and Divide-by-8 Mode, DCS Enabled or DCS Disabled3 Aperture Delay (tA) Full 1.0 1.0 1.0 ns Aperture Uncertainty (Jitter, tJ) Full 0.07 0.07 0.07 ps rms DATA OUTPUT PARAMETERS CMOS Mode Data Propagation Delay (tPD) Full 2.4 2.8 3.4 2.4 2.8 3.4 2.4 2.8 3.4 ns DCO Propagation Delay (tDCO)4 Full 2.7 3.4 4.2 2.7 3.4 4.2 2.7 3.4 4.2 ns DCO to Data Skew (tSKEW) Full 0.3 0.6 0.9 0.3 0.6 0.9 0.3 0.6 0.9 ns Pipeline Delay (Latency) Full 12 12 12 Cycles LVDS Mode Data Propagation Delay (tPD) Full 2.6 3.4 4.2 2.6 3.4 4.2 2.6 3.4 4.2 ns DCO Propagation Delay (tDCO)4 Full 3.3 3.8 4.3 3.3 3.8 4.3 3.3 3.8 4.3 ns DCO to Data Skew (tSKEW) −0.3 +0.4 +1.2 −0.3 +0.4 +1.2 −0.3 +0.4 +1.2 Pipeline Delay (Latency) Full 12.5 12.5 12.5 Cycles Wake-Up Time5 Full 500 500 500 μs OUT-OF-RANGE RECOVERY TIME Full 2 2 2 Cycles 1 The suffix following the part number refers to the model found in the Ordering Guide section. 2 Conversion rate is the clock rate after the divider. 3 See the Input Clock Divider section for additional information on using the DCS with the input clock divider. 4 Additional DCO delay can be added by writing to Bit 0 through Bit 4 in SPI Register 0x17 (see Table 17). 5 Wake-up time is defined as the time required to return to normal operation from power-down mode. Rev. C | Page 8 of 44 Document Outline Features Applications Product Highlights Functional Block Diagram Table of Contents Revision History General Description Specifications ADC DC Specifications ADC AC Specifications Digital Specifications Switching Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Characteristics ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Equivalent Circuits Theory of Operation ADC Architecture Analog Input Considerations Input Common Mode Dither Differential Input Configurations Voltage Reference Internal Reference Connection External Reference Operation Clock Input Considerations Clock Input Options Clock Duty Cycle Input Clock Divider Jitter Considerations Power Dissipation and Standby Mode Digital Outputs Digital Output Enable Function (OEB) Timing Data Clock Output (DCO) Built-In Self-Test (BIST) and Output Test Built-In Self-Test (BIST) Output Test Modes Serial Port Interface (SPI) Configuration Using the SPI Hardware Interface Configuration Without the SPI SPI Accessible Features Memory Map Reading the Memory Map Register Table Open Locations Default Values Logic Levels Transfer Register Map Memory Map Register Table Memory Map Register Descriptions Sync Control (Register 0x100) Applications Information Design Guidelines Power and Ground Recommendations LVDS Operation Exposed Paddle Thermal Heat Slug Recommendations VCM RBIAS Reference Decoupling SPI Port Outline Dimensions Ordering Guide
