link to page 8 AD9258AD9258BCPZ-80AD9258BCPZ-105AD9258BCPZ-125Parameter1Temp Min Typ Max MinTyp Max Min Typ Max Unit WORST OTHER (HARMONIC OR SPUR) Without Dither fIN = 2.4 MHz 25°C −100 −100 −99 dBc fIN = 70 MHz 25°C −100 −96 −99 −94 −98 −94 dBc Full −96 −94 −94 dBc fIN = 140 MHz 25°C −97 −97 −97 dBc fIN = 200 MHz 25°C −95 −95 −95 dBc With On-Chip Dither fIN = 2.4 MHz 25°C −109 −107 −107 dBc fIN = 70 MHz 25°C −105 −96 −106 −95 −105 −95 dBc Full −96 −95 −95 dBc fIN = 140 MHz 25°C −106 −104 −103 dBc fIN = 200 MHz 25°C −102 −104 −97 dBc TWO-TONE SFDR WITHOUT DITHER fIN = 29 MHz (−7 dBFS ), 32 MHz (−7 dBFS ) 25°C 93 92 90 dBc fIN = 169 MHz (−7 dBFS ),172 MHz (−7 dBFS ) 25°C 81 80 82 dBc CROSSTALK2 Full −95 −95 −95 dB ANALOG INPUT BANDWIDTH 25°C 650 650 650 MHz 1 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for a complete set of definitions. 2 Crosstalk is measured at 100 MHz with −1.0 dBFS on one channel and no input on the alternate channel. DIGITAL SPECIFICATIONS AVDD = 1.8 V, DRVDD = 1.8 V, maximum sample rate, VIN = −1.0 dBFS differential input, 1.0 V internal reference, and DCS enabled, unless otherwise noted. Table 3. Parameter TemperatureMinTypMaxUnit DIFFERENTIAL CLOCK INPUTS (CLK+, CLK−) Logic Compliance CMOS/LVDS/LVPECL Internal Common-Mode Bias Full 0.9 V Differential Input Voltage Full 0.3 3.6 V p-p Input Voltage Range Full AGND AVDD V Input Common-Mode Range Full 0.9 1.4 V High Level Input Current Full −100 +100 μA Low Level Input Current Full −100 +100 μA Input Capacitance Full 4 pF Input Resistance Full 8 10 12 kΩ SYNC INPUT Logic Compliance CMOS Internal Bias Full 0.9 V Input Voltage Range Full AGND AVDD V High Level Input Voltage Full 1.2 AVDD V Low Level Input Voltage Full AGND 0.6 V High Level Input Current Full −100 +100 μA Low Level Input Current Full −100 +100 μA Input Capacitance Full 1 pF Input Resistance Full 12 16 20 kΩ Rev. A | Page 7 of 44 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS ADC DC SPECIFICATIONS ADC AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Input Common Mode Common-Mode Voltage Servo Dither Large-Signal FFT Small-Signal FFT Static Linearity Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations CHANNEL/CHIP SYNCHRONIZATION POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) TIMING Data Clock Output (DCO) BUILT-IN SELF-TEST (BIST) AND OUTPUT TEST BUILT-IN SELF-TEST (BIST) OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Transfer Register Map Channel-Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Sync Control (Register 0x100) Bits[7:3]—Reserved Bit 2—Clock Divider Next Sync Only Bit 1—Clock Divider Sync Enable Bit 0—Master Sync Enable APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations LVDS Operation Exposed Paddle Thermal Heat Slug Recommendations VCM RBIAS Reference Decoupling SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
