Datasheet AD7693 (Analog Devices) - 2
Description16-Bit, ±0.5 LSB, 500 kSPS PulSAR® Differential A/D Converter in MSOP/QFN
Pages / Page25 / 2 — AD7693* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 750 Kb
AD7693* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD7693* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• SAR ADC & Driver Quick-Match Guide
EVALUATION KITS Technical Articles
• AD7693 Evaluation Kit • MS-1779: Nine Often Overlooked ADC Specifications • Precision ADC PMOD Compatible Boards • MS-2210: Designing Power Supplies for High Speed ADC
Tutorials DOCUMENTATION
• MT-002: What the Nyquist Criterion Means to Your
Application Notes
Sampled Data System Design • AN-742: Frequency Domain Response of Switched- • MT-074: Differential Drivers for Precision ADCs Capacitor ADCs • AN-931: Understanding PulSAR ADC Support Circuitry
DESIGN RESOURCES
• AN-932: Power Supply Sequencing • AD7693 Material Declaration
Data Sheet
• PCN-PDN Information • AD7693: 16-Bit, ±0.5 LSB, 500 kSPS PulSAR® Differential • Quality And Reliability ADC in MSOP/LFCSP Data Sheet • Symbols and Footprints
Technical Books
• The Data Conversion Handbook, 2005
DISCUSSIONS User Guides
View all AD7693 EngineerZone Discussions. • UG-340: Evaluation Board for the 10-Lead Family 14-/16-/ 18-Bit PulSAR ADCs
SAMPLE AND BUY
• UG-682: 6-Lead SOT-23 ADC Driver for the 8-/10-Lead Visit the product page to see pricing options. Family of 14-/16-/18-Bit PulSAR ADC Evaluation Boards
TECHNICAL SUPPORT SOFTWARE AND SYSTEMS REQUIREMENTS
Submit a technical question or find your regional support • AD7693 FMC-SDP Interposer & Evaluation Board / Xilinx number. KC705 Reference Design • BeMicro FPGA Project for AD7693 with Nios driver
DOCUMENT FEEDBACK TOOLS AND SIMULATIONS
Submit feedback for this data sheet. • AD7685 IBIS Models
Document Outline Features Applications Application Diagram General Description Table of Contents Revision History Specification Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Typical Performance Characteristics Theory of Operation Circuit Information Converter Operation Transfer Functions Typical Connection Diagram Analog Inputs Driver Amplifier Choice Single-Ended-to-Differential Driver Voltage Reference Input Power Supply Supplying the ADC from the Reference Digital Interface /CS Mode, 3-Wire Without Busy Indicator /CS Mode, 3-Wire with Busy Indicator /CS Mode, 4-Wire Without Busy Indicator /CS Mode, 4-Wire with Busy Indicator Chain Mode Without Busy Indicator Chain Mode with Busy Indicator Application Hints Layout Evaluating the AD7693 Performance Outline Dimensions Ordering Guide
