Datasheet AD7622 (Analog Devices) - 7
Description16-Bit, 1.5 LSB INL, 2 MSPS PulSAR® ADC
Pages / Page29 / 7 — AD7622. Table 4. Serial Clock Timings in Master Read After Convert Mode …
File Format / SizePDF / 598 Kb
AD7622. Table 4. Serial Clock Timings in Master Read After Convert Mode DIVSCLK[1]. 0 0 1 1. DIVSCLK[0]. Symbol 0 1 0 1 Unit
AD7622 Table 4 Serial Clock Timings in Master Read After Convert Mode DIVSCLK[1] 0 0 1 1 DIVSCLK[0] Symbol 0 1 0 1 Unit
link to page 21 link to page 22 link to page 7
AD7622
1 See the Conversion Control section. 2 All timings for wideband warp mode are the same as warp mode. 3 In warp mode only, the maximum time between conversions is 1 ms; otherwise, there is no required maximum time. 4 See the Digital Interface section and the RESET section. 5 In serial interface modes, the SYNC, SCLK, and SDOUT timings are defined with a maximum load CL of 10 pF; otherwise, the load is 60 pF maximum. 6 In serial master read during convert mode. See Table 4 for serial master read after convert mode timing specifications.
Table 4. Serial Clock Timings in Master Read After Convert Mode DIVSCLK[1] 0 0 1 1 DIVSCLK[0] Symbol 0 1 0 1 Unit
SYNC to SCLK First Edge Delay Minimum t18 3 3 3 3 ns Internal SCLK Period Minimum t19 8 16 32 64 ns Internal SCLK Period Maximum t19 20 40 60 140 ns Internal SCLK High Minimum t20 2 8 16 32 ns Internal SCLK Low Minimum t21 2 8 16 32 ns SDOUT Valid Setup Time Minimum t22 1 5 15 5 ns SDOUT Valid Hold Time Minimum t23 0 0.5 10 28 ns SCLK Last Edge to SYNC Delay Minimum t24 0 0.5 9 26 ns BUSY High Width Maximum Warp Mode t28 0.64 0.92 1.47 2.57 μs Normal Mode t28 0.76 1.04 1.59 2.69 μs
500µA IOL TO OUTPUT 1.4V PIN CL 50pF 2V 0.8V 500µA IOH tDELAY tDELAY NOTE 2V 2V IN SERIAL INTERFACE MODES, THE SYNC, SCLK, AND
003
SDOUT TIMING ARE DEFINED WITH A MAXIMUM LOAD
02
0.8V 0.8V
23- -0 60
C
0
L OF 10pF; OTHERWISE, THE LOAD IS 60pF MAXIMUM.
23600 Figure 3. Load Circuit for Digital Interface Timing, Figure 4. Voltage Reference Levels for Timing SDOUT, SYNC, and SCLK Outputs, C L = 10 pF Rev. 0 | Page 6 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TIMING SPECIFICATIONS PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION CIRCUIT INFORMATION CONVERTER OPERATION MODES OF OPERATION TRANSFER FUNCTIONS TYPICAL CONNECTION DIAGRAM ANALOG INPUTS MULTIPLEXED INPUTS DRIVER AMPLIFIER CHOICE Single-to-Differential Driver VOLTAGE REFERENCE INPUT Internal Reference (PDBUF = Low, PDREF = Low) External 1.2 V Reference and Internal Buffer (PDBUF = Low, PDREF = High) External 2.5 V Reference (PDBUF = High, PDREF = High) Reference Decoupling Temperature Sensor POWER SUPPLY Power Sequencing Power-Up CONVERSION CONTROL INTERFACES DIGITAL INTERFACE RESET PARALLEL INTERFACE Master Parallel Interface Slave Parallel Interface 8-Bit Interface (Master or Slave) SERIAL INTERFACE MASTER SERIAL INTERFACE Internal Clock SLAVE SERIAL INTERFACE External Clock External Discontinuous Clock Data Read After Conversion External Clock Data Read During Previous Conversion MICROPROCESSOR INTERFACING SPI Interface (ADSP-219x) APPLICATION HINTS LAYOUT EVALUATING THE AD7622 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
