Datasheet AD7327 (Analog Devices) - 3
Description500 kSPS, 8-Channel, Software Selectable True bipolar Input, 12-Bit Plus Sign A/D Converter
Pages / Page37 / 3 — AD7327. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 12/13—Rev. A to …
File Format / SizePDF / 776 Kb
AD7327. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 12/13—Rev. A to Rev. B. 1/10—Rev. 0 to Rev. A
AD7327 Data Sheet TABLE OF CONTENTS REVISION HISTORY 12/13—Rev A to Rev B 1/10—Rev 0 to Rev A
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 8 link to page 9 link to page 9 link to page 10 link to page 11 link to page 15 link to page 17 link to page 17 link to page 17 link to page 18 link to page 20 link to page 20 link to page 22 link to page 23 link to page 23 link to page 23 link to page 24 link to page 25 link to page 26 link to page 28 link to page 28 link to page 28 link to page 29 link to page 29 link to page 29 link to page 30 link to page 30 link to page 31 link to page 32 link to page 33 link to page 33 link to page 33 link to page 34 link to page 34 link to page 34 link to page 35 link to page 35
Features .. 1 Sequence Register ... 23 Functional Block Diagram .. 1 Range Registers ... 24 General Description ... 1 Sequencer Operation ... 25 Product Highlights ... 1 Reference ... 27 Revision History ... 2 VDRIVE .. 27 Specifications ... 3 Temperature Indicator ... 27 Timing Specifications .. 7 Modes of Operation ... 28 Absolute Maximum Ratings .. 8 Normal Mode .. 28 ESD Caution .. 8 Full Shutdown Mode .. 28 Pin Configuration and Function Descriptions ... 9 Autoshutdown Mode ... 29 Typical Performance Characteristics ... 10 Autostandby Mode ... 29 Terminology .. 14 Power vs. Throughput Rate ... 30 Theory of Operation .. 16 Serial Interface .. 31 Circuit Information .. 16 Microprocessor Interfacing ... 32 Converter Operation .. 16 AD7327 to ADSP-21xx .. 32 Analog Input Structure .. 17 AD7327 to ADSP-BF53x ... 32 Typical Connection Diagram ... 19 Application Hints ... 33 Analog Input ... 19 Layout and Grounding .. 33 Driver Amplifier Choice .. 21 Power Supply Configuration .. 33 Registers ... 22 Outline Dimensions ... 34 Addressing Registers .. 22 Ordering Guide .. 34 Control Register .. 22
Changes to Circuit Information Section and Table 6 .. 16 Changes to Addressing Registers Section .. 22 Changes to Power Supply Configuration Section .. 33 Changes to Ordering Guide .. 34
Change to Features and Product Highlights Sections ... 1 Changes to Table 2 .. 5 Change to Endnote 1 in Table 4 .. 8 Added Power Supply Configuration Section, Figure 56, and Table 16 .. 33
1/06—Revision 0: Initial Version
Rev. B | Page 2 of 36 Document Outline Features Functional Block Diagram General Description Product Highlights Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Circuit Information Converter Operation Output Coding Transfer Functions Analog Input Structure Track-and-Hold Section Typical Connection Diagram Analog Input Single-Ended Inputs True Differential Mode Pseudo Differential Inputs Driver Amplifier Choice Registers Addressing Registers Control Register Sequence Register Range Registers Sequencer Operation Reference VDRIVE Temperature Indicator Modes of Operation Normal Mode Full Shutdown Mode Autoshutdown Mode Autostandby Mode Power vs. Throughput Rate Serial Interface Microprocessor Interfacing AD7327 to ADSP-21xx AD7327 to ADSP-BF53x Application Hints Layout and Grounding Power Supply Configuration Outline Dimensions Ordering Guide
