Datasheet AD7266 (Analog Devices) - 7
DescriptionDifferential/Single-Ended Input, Dual, Simultaneous Sampling, 2 MSPS, 12-Bit, 3-Channel SAR A/D Converter
Pages / Page29 / 7 — AD7266. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD CAUTION
File Format / SizePDF / 702 Kb
AD7266 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
link to page 7
AD7266 ABSOLUTE MAXIMUM RATINGS Table 3.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress V rating only; functional operation of the device at these or any DD to AGND −0.3 V to +7 V DV other conditions above those indicated in the operational DD to DGND −0.3 V to +7 V V section of this specification is not implied. Exposure to absolute DRIVE to DGND −0.3 V to DVDD V maximum rating conditions for extended periods may affect DRIVE to AGND −0.3 V to AVDD AV device reliability. DD to DVDD −0.3 V to +0.3 V AGND to DGND −0.3 V to +0.3 V Analog Input Voltage to AGND −0.3 V to AVDD + 0.3 V
ESD CAUTION
Digital Input Voltage to DGND −0.3 V to +7 V Digital Output Voltage to GND −0.3 V to VDRIVE + 0.3 V VREF to AGND −0.3 V to AVDD + 0.3 V Input Current to Any Pin Except Supplies1 ±10 mA Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C LFCSP/TQFP θJA Thermal Impedance 108.2°C/W (LFCSP) 55°C/W (TQFP) θJC Thermal Impedance 32.71°C/W (LFCSP) Lead Temperature, Soldering Reflow Temperature (10 to 30 sec) 255°C ESD 1.5 kV 1 Transient currents of up to 100 mA will not cause latch up. Rev. B | Page 6 of 28 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION ANALOG INPUT STRUCTURE ANALOG INPUTS Single-Ended Mode Differential Mode Driving Differential Inputs Using an Op Amp Pair Pseudo Differential Mode ANALOG INPUT SELECTION OUTPUT CODING TRANSFER FUNCTIONS DIGITAL INPUTS VDRIVE MODES OF OPERATION NORMAL MODE PARTIAL POWER-DOWN MODE FULL POWER-DOWN MODE POWER-UP TIMES POWER vs. THROUGHPUT RATE SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7266 TO ADSP-218x AD7266 TO ADSP-BF53x AD7266 TO TMS320C541 AD7266 TO DSP563xx APPLICATION HINTS GROUNDING AND LAYOUT PCB DESIGN GUIDELINES FOR LFCSP EVALUATING THE AD7266 PERFORMANCE OUTLINE DIMENSIONS ORDERING GUIDE
