Datasheet AD9216 (Analog Devices) - 2
Description10-Bit, 65/80/105 MSPS Dual A/D Converter
Pages / Page41 / 2 — AD9216* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionA
AD9216* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9216* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9216 IBIS Models
EVALUATION KITS
• AD9216 Evaluation Board
REFERENCE MATERIALS Technical Articles DOCUMENTATION
• Matching An ADC To A Transformer
Application Notes
• MS-2210: Designing Power Supplies for High Speed ADC • AN-1142: Techniques for High Speed ADC PCB Layout • AN-282: Fundamentals of Sampled Data Systems
DESIGN RESOURCES
• AN-345: Grounding for Low-and-High-Frequency Circuits • AD9216 Material Declaration • AN-501: Aperture Uncertainty and ADC System • PCN-PDN Information Performance • Quality And Reliability • AN-715: A First Approach to IBIS Models: What They Are • Symbols and Footprints and How They Are Generated • AN-737: How ADIsimADC Models an ADC
DISCUSSIONS
• AN-741: Little Known Characteristics of Phase Noise View all AD9216 EngineerZone Discussions. • AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter
SAMPLE AND BUY
• AN-803: Pin Compatible High Speed ADCs Simplify Design Tasks Visit the product page to see pricing options. • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs
TECHNICAL SUPPORT
• AN-835: Understanding High Speed ADC Testing and Submit a technical question or find your regional support Evaluation number. • AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual
DOCUMENT FEEDBACK
• AN-935: Designing an ADC Transformer-Coupled Front Submit feedback for this data sheet. End
Data Sheet
• AD9216: 10-Bit, 105 MSPS Dual A/D Converter Data Sheet
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS LOGIC SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT Differential Input Configurations Single-Ended Input Configuration CLOCK INPUT AND CONSIDERATIONS POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS OUTPUT CODING TIMING DATA FORMAT VOLTAGE REFERENCE Internal Reference Connection External Reference Operation Shared Reference Mode DUAL ADC LFCSP PCB POWER CONNECTOR ANALOG INPUTS OPTIONAL OPERATIONAL AMPLIFIER CLOCK VOLTAGE REFERENCE DATA OUTPUTS LFCSP EVALUATION BOARD BILL OF MATERIALS (BOM) LFCSP PCB SCHEMATICS LFCSP PCB LAYERS THERMAL CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
