Datasheet AD7685 (Analog Devices) - 9
Description16-Bit, 250 kSPS PulSAR® ADC in MSOP/QFN
Pages / Page29 / 9 — AD7685. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. REF 1. …
RevisionD
File Format / SizePDF / 549 Kb
AD7685. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. REF 1. 10 VIO. VDD 2. SDI. IN+ 3. SCK. TOP VIEW. IN– 4. (Not to Scale). SDO. REF
AD7685 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS REF 1 10 VIO VDD 2 SDI IN+ 3 SCK TOP VIEW IN– 4 (Not to Scale) SDO REF
link to page 9
AD7685 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS REF 1 10 VIO VDD 2 9 SDI AD7685 IN+ 3 8 SCK TOP VIEW IN– 4 (Not to Scale) 7 SDO REF 1 10 VIO GND 5 6 CNV VDD 2 9 SDI AD7685 IN+ 3 8 SCK TOP VIEW NOTES IN– 4 (Not to Scale) 7 SDO
004
1. EXPOSED PAD CONNECTED TO GND. THIS
005
GND 5 6 CNV CONNECTION IS NOT REQUIRED TO MEET THE ELECTRICAL PERFORMANCES.
02968- 02968- Figure 5. 10-Lead MSOP Pin Configuration Figure 6. 10-Lead LFCSP Pin Configuration
Table 7. Pin Function Descriptions Pin No Mnemonic Type1 Description
1 REF AI Reference Input Voltage. The REF range is from 0.5 V to VDD. It is referred to the GND pin. This pin should be decoupled closely to the pin with a 10 µF capacitor. 2 VDD P Power Supply. 3 IN+ AI Analog Input. It is referred to IN−. The voltage range, that is, the difference between IN+ and IN−, is 0 V to VREF. 4 IN− AI Analog Input Ground Sense. Connect to the analog ground plane or to a remote sense ground. 5 GND P Power Supply Ground. 6 CNV DI Convert Input. This input has multiple functions. On its leading edge, it initiates the conversions and selects the interface mode of the part, chain, or CS mode. In CS mode, it enables the SDO pin when low. In chain mode, the data should be read when CNV is high. 7 SDO DO Serial Data Output. The conversion result is output on this pin. It is synchronized to SCK. 8 SCK DI Serial Data Clock Input. When the part is selected, the conversion result is shifted out by this clock. 9 SDI DI Serial Data Input. This input provides multiple features. It selects the interface mode of the ADC as follows: Chain mode is selected if SDI is low during the CNV rising edge. In this mode, SDI is used as a data input to daisy chain the conversion results of two or more ADCs onto a single SDO line. The digital data level on SDI is output on SDO with a delay of 16 SCK cycles. CS mode is selected if SDI is high during the CNV rising edge. In this mode, either SDI or CNV can enable the serial output signals when low, and if SDI or CNV is low when the conversion is complete, the BUSY indicator feature is enabled. 10 VIO P Input/Output Interface Digital Power. Nominal y at the same supply as the host interface (1.8 V, 2.5 V, 3 V, or 5 V). EPAD N/A Exposed Pad. Exposed pad connected to GND. This connection is not required to meet the electrical performances. 1AI = analog input, DI = digital input, DO = digital output, and P = power. Rev. D | Page 8 of 28 Document Outline Features Applications Typical Application Circuit General Description Table of Contents Revision History Specifications Timing Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Typical Performance Characteristics Theory of Operation Circuit Information Converter Operation Transfer Functions Typical Connection Diagram Analog Inputs Driver Amplifier Choice Voltage Reference Input Power Supply Supplying the ADC from the Reference Digital Interface CS/ Mode 3-Wire, No BUSY Indicator CS/ Mode 3-Wire with BUSY Indicator CS/ Mode 4-Wire, No BUSY Indicator CS/ Mode 4-Wire with BUSY Indicator Chain Mode, No BUSY Indicator Chain Mode with BUSY Indicator Application Hints Layout Evaluating the Performance of the AD7685 True 16-Bit Isolated Application Example Outline Dimensions Ordering Guide
