Datasheet AD7790 (Analog Devices)
Description | 16-Bit, Single-Channel, Ultra Low Power, Sigma Delta A/D Converter |
Pages / Page | 21 / 1 — Low Power, 16-Bit. Buffered Sigma-Delta ADC. Data Sheet. AD7790. … |
Revision | A |
File Format / Size | PDF / 471 Kb |
Low Power, 16-Bit. Buffered Sigma-Delta ADC. Data Sheet. AD7790. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Power. GND. REFIN
Low Power, 16-Bit Buffered Sigma-Delta ADC Data Sheet AD7790 FEATURES FUNCTIONAL BLOCK DIAGRAM Power GND V REFIN Supply: 2.5 V to 5.25 V operation DD Normal: 75 μA maximum VDD INTERNAL Power-down: 1 μA maximum CLOCK RMS noise: 1.1 μV at 9.5 Hz update rate 16-bit p-p resolution 16-BIT SERIAL AIN DIGITAL BUF ADC INTERFACE PGA Integral nonlinearity: 3.5 ppm typical Simultaneous 50 Hz and 60 Hz rejection AD7790 Internal clock oscillator GND Programmable gain amplifier
03538-0-001
Rail-to-rail input buffer
Figure 1.
VDD monitor channel Temperature range: –40°C to +105°C GENERAL DESCRIPTION 10-lead MSOP
The AD7790 is a low power, complete analog front end for low frequency measurement applications. It contains a low
INTERFACE
noise 16-bit ∑-Δ ADC with one differential input that can be
3-wire serial
buffered or unbuffered along with a digital PGA, which allows
SPI®, QSPI™, MICROWIRE™, and DSP compatible
gains of 1, 2, 4, and 8.
Schmitt trigger on SCLK
The device operates from an internal clock. Therefore, the user
does not have to supply a clock source to the device. The output
Smart transmitters
data rate from the part is software programmable and can be
Battery applications
varied from 9.5 Hz to 120 Hz, with the rms noise equal to
Portable instrumentation
1.1 μV at the lower update rate. The internal clock frequency
Sensor measurement
can be divided by a factor of 2, 4, or 8, which leads to a reduc-
Temperature measurement
tion in the current consumption. The update rate, cutoff
Pressure measurement
frequency, and settling time will scale with the clock frequency.
Weigh scales
The part operates with a power supply from 2.5 V to 5.25 V.
4 to 20 mA loops
When operating from a 3 V supply, the power dissipation for the part is 225 μW maximum. It is housed in a 10-lead MSOP.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no re- sponsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2004–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline AD7790—Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics On-Chip Registers Communications Register (RS1, RS0 = 0, 0) Status Register (RS1, RS0 = 0, 0; Power-on/Reset = 0x88) Mode Register (RS1, RS0 = 0, 1; Power-on/Reset = 0x02) Filter Register (RS1, RS0 = 1, 0; Power-on/Reset = 0x04) Data Register (RS1, RS0 = 1, 1; Power-on/Reset = 0x0000) ADC Circuit Information Overview Noise Performance Reduced Current Modes Digital Interface Single Conversion Mode Continuous Conversion Mode Continuous Read Mode Circuit Description Analog Input Channel Programmable Gain Amplifier Bipolar Configuration Data Output Coding Reference Input VDD Monitor Grounding and Layout Outline Dimensions Ordering Guide
