link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 16 AD9238SPECIFICATIONS DC SPECIFICATIONS AVDD = 3 V, DRVDD = 2.5 V, maximum sample rate, CLK_A = CLK_B; AIN = −0.5 dBFS differential input, 1.0 V internal reference, TMIN to TMAX, DCS enabled, unless otherwise noted. Table 1.TestAD9238BST/BCP-20AD9238BST/BCP-40AD9238BST/BCP-65ParameterTempLevelMinTypMaxMinTypMaxMinTypMaxUnit RESOLUTION Full VI 12 12 12 Bits ACCURACY No Missing Codes Guaranteed Full VI 12 12 12 Bits Offset Error Full VI ±0.30 ±1.2 ±0.50 ±1.1 ±0.50 ±1.1 % FSR Gain Error1 Full IV ±0.30 ±2.2 ±0.50 ±2.4 ±0.50 ±2.5 % FSR Differential Nonlinearity (DNL)2 Full V ±0.35 ±0.35 ±0.35 LSB 25°C I ±0.35 ±0.9 ±0.35 ±0.8 ±0.35 ±1.0 LSB Integral Nonlinearity (INL)2 Full V ±0.45 ±0.60 ±0.70 LSB 25°C I ±0.40 ±1.4 ±0.50 ±1.4 ±0.55 ±1.75 LSB TEMPERATURE DRIFT Offset Error Full V ±4 ±4 ±6 μV/°C Gain Error Full V ±12 ±12 ±12 ppm/°C INTERNAL VOLTAGE REFERENCE Output Voltage Error (1 V Mode) Full VI ±5 ±35 ±5 ±35 ±5 ±35 mV Load Regulation @ 1.0 mA Full V 0.8 0.8 0.8 mV Output Voltage Error (0.5 V Mode) Full V ±2.5 ±2.5 ±2.5 mV Load Regulation @ 0.5 mA Full V 0.1 0.1 0.1 mV INPUT REFERRED NOISE Input Span = 1 V 25°C V 0.54 0.54 0.54 LSB rms Input Span = 2.0 V 25°C V 0.27 0.27 0.27 LSB rms ANALOG INPUT Input Span = 1.0 V Full IV 1 1 1 V p-p Input Span = 2.0 V Full IV 2 2 2 V p-p Input Capacitance3 Full V 7 7 7 pF REFERENCE INPUT RESISTANCE Full V 7 7 7 kΩ POWER SUPPLIES Supply Voltages AVDD Full IV 2.7 3.0 3.6 2.7 3.0 3.6 2.7 3.0 3.6 V DRVDD Full IV 2.25 3.0 3.6 2.25 3.0 3.6 2.25 3.0 3.6 V Supply Current IAVDD2 Full V 60 110 200 mA IDRVDD2 Full V 4 10 14 mA PSRR Full V ±0.01 ±0.01 ±0.01 % FSR POWER CONSUMPTION DC Input4 Full V 180 330 600 mW Sine Wave Input2 Full VI 190 212 360 397 640 698 mW Standby Power5 Full V 2.0 2.0 2.0 mW MATCHING CHARACTERISTICS Offset Error 25°C V ±0.1 ±0.1 ±0.1 % FSR Gain Error 25°C V ±0.05 ±0.05 ±0.05 % FSR 1 Gain error and gain temperature coefficient are based on the ADC only (with a fixed 1.0 V external reference). 2 Measured at maximum clock rate with a low frequency sine wave input and approximately 5 pF loading on each output bit. 3 Input capacitance refers to the effective capacitance between one differential input pin and AVSS. Refer to Figure 2 f 9 or the equivalent analog input structure. 4 Measured with dc input at maximum clock rate. 5 Standby power is measured with the CLK_A and CLK_B pins inactive (that is, set to AVDD or AGND). Rev. C | Page 4 of 48 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT Differential Input Configurations Single-Ended Input Configuration CLOCK INPUT AND CONSIDERATIONS POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS TIMING DATA FORMAT VOLTAGE REFERENCE Internal Reference Connection External Reference Operation AD9238 LQFP EVALUATION BOARD CLOCK CIRCUITRY ANALOG INPUTS REFERENCE CIRCUITRY DIGITAL CONTROL LOGIC OUTPUTS LQFP EVALUATION BOARD BILL OF MATERIALS (BOM) LQFP EVALUATION BOARD SCHEMATICS LQFP PCB LAYERS DUAL ADC LFCSP PCB POWER CONNECTOR ANALOG INPUTS OPTIONAL OPERATIONAL AMPLIFIER CLOCK VOLTAGE REFERENCE DATA OUTPUTS LFCSP EVALUATION BOARD BILL OF MATERIALS (BOM) LFCSP PCB SCHEMATICS LFCSP PCB LAYERS THERMAL CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
