Datasheet AD7485 (Analog Devices) - 6
Description14-Bit, 1 MSPS SAR ADC
Pages / Page15 / 6 — AD7485. PIN FUNCTION DESCRIPTIONS. Pin No. Mnemonic. Description
RevisionA
File Format / SizePDF / 826 Kb
AD7485 PIN FUNCTION DESCRIPTIONS Pin No Mnemonic Description
AD7485 PIN FUNCTION DESCRIPTIONS Pin No. Mnemonic Description
1, 5, 13, 46 AVDD Positive Power Supply for Analog Circuitry 2 CBIAS Decoupling Pin for Internal Bias Voltage. A 1 nF capacitor should be placed between this pin and AGND. 3, 4, 6, 11, 12, AGND Power Supply Ground for Analog Circuitry 14, 15, 47, 48 7 VIN Analog Input. Single-ended analog input channel. 8 REFOUT Reference Output. REFOUT connects to the output of the internal 2.5 V reference buffer. A 470 nF capacitor must be placed between this pin and AGND. 9 REFIN Reference Input. A 470 nF capacitor must be placed between this pin and AGND. When using an external voltage reference source, the reference voltage should be applied to this pin. 10 REFSEL Reference Decoupling Pin. When using the internal reference, a 1 nF capacitor must be connected from this pin to AGND. When using an external reference source, this pin should be connected directly to AGND. 16 STBY Standby Logic Input. When this pin is logic high, the device will be placed in STANDBY mode. See the Power Saving section for further details. 17 NAP Nap Logic Input. When this pin is logic high, the device will be placed in a very low power mode. See the Power Saving section for further details. 18 MCLK Master Clock Input. This is the input for the master clock, which controls the conversion cycle. The fre- quency of this clock may be up to 25 MHz. Twenty-four clock cycles are required for each conversion. 19, 20, 22–28 DGND Ground Reference for Digital Circuitry 30, 31, 33, 34 37–39, 43, 44 21 SDO Serial Data Output. The conversion data is latched out on this pin on the rising edge of SCO. It should be latched into the receiving serial port of the DSP on the falling edge of SCO. The over- range bit is latched out first, then 14 bits of data (MSB first) followed by a trailing zero. 29, 45 DVDD Positive Power Supply for Digital Circuitry 32 VDRIVE Logic Power Supply Input. The voltage supplied at this pin determines at what voltage the interface logic of the AD7485 will operate. 35 TFS Transmit Frame Sync Input. In Serial Mode 2, this pin acts as a framing signal for the serial data being clocked out on SDO. A falling edge on TFS brings SDO out of three-state and the data starts to get clocked out on the next rising edge of SCO. 36 SMODE Serial Mode Input. A logic low on this pin selects Serial Mode 1 and a logic high selects Serial Mode 2. See the Serial Interface section for further details. 40 SCO Serial Clock Output. This clock is derived from MCLK and is used to latch conversion data from the device. See the Serial Interface section for further details. 41 CONVST Convert Start Logic Input. A conversion is initiated on the falling edge of the CONVST signal. The input track/hold amplifier goes from track mode to hold mode and the conversion process commences. 42 RESET Reset Logic Input. A falling edge on this pin resets the internal state machine and terminates a conversion that may be in progress. Holding this pin low keeps the part in a reset state. REV. A –5– Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS TERMINOLOGY Integral Nonlinearity Differential Nonlinearity Offset Error Gain Error Track/Hold Acquisition Time Signal to (Noise + Distortion) Ratio Total Harmonic Distortion Peak Harmonic or Spurious Noise Intermodulation Distortion Typical Performance Characteristics CIRCUIT DESCRIPTION CONVERTER OPERATION ADC TRANSFER FUNCTION POWER SAVING SERIAL INTERFACE Driving the CONVST Pin Board Layout and Grounding OUTLINE DIMENSIONS
