Datasheet AD7866 (Analog Devices) - 2
DescriptionDual 1MSPS, 12-Bit, 2-Channel SAR ADC with Serial Interface
Pages / Page25 / 2 — AD7866* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 435 Kb
AD7866* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD7866* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD7866 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD7866 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all AD7866 EngineerZone Discussions. • AD7866: Dual 1 MSPS, 12-Bit, 2-Channel SAR ADC with Serial Interface Data Sheet
SAMPLE AND BUY
Visit the product page to see pricing options.
TOOLS AND SIMULATIONS
• AD7866 IBIS Model
TECHNICAL SUPPORT
Submit a technical question or find your regional support
REFERENCE DESIGNS
number. • CN0323 • CN0341
DOCUMENT FEEDBACK
• CN0368 Submit feedback for this data sheet.
REFERENCE MATERIALS Technical Articles
• MS-2210: Designing Power Supplies for High Speed ADC
Document Outline FEATURES GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS TERMINOLOGY Integral Nonlinearity Differential Nonlinearity Offset Error Offset Error Match Gain Error Gain Error Match Zero Code Error Zero Code Error Match Positive Gain Error Negative Gain Error Track-and-Hold Acquisition Time Signal-to-(Noise + Distortion) Ratio (SNDR) Total Harmonic Distortion (THD) Peak Harmonic or Spurious Noise Intermodulation Distortion Channel-to-Channel Isolation PSR (Power Supply Rejection) PERFORMANCE CURVES Typical Performance Characteristics CIRCUIT INFORMATION CONVERTER OPERATION ANALOG INPUT Analog Input Ranges Handling Bipolar Input Signals Transfer Functions Digital Inputs REFERENCE CONFIGURATION OPTIONS MODES OF OPERATION Normal Mode Partial Power-Down Mode Full Power-Down Mode POWER-UP TIMES POWER VS. THROUGHPUT RATE SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7866 to ADSP-218x AD7866 to TMS320C541 AD7866 to DSP-563xx APPLICATION HINTS Grounding and Layout Evaluating the AD7866 Performance OUTLINE DIMENSIONS Revision History
