Datasheet AD7866 (Analog Devices) - 3
DescriptionDual 1MSPS, 12-Bit, 2-Channel SAR ADC with Serial Interface
Pages / Page25 / 3 — AD7866–SPECIFICATIONS (TA = TMIN to TMAX, VDD = 2.7 V to 5.25 V, VDRIVE = …
File Format / SizePDF / 435 Kb
AD7866–SPECIFICATIONS (TA = TMIN to TMAX, VDD = 2.7 V to 5.25 V, VDRIVE = 2.7 V to 5.25 V, Reference = 2.5 V
AD7866–SPECIFICATIONS (TA = TMIN to TMAX, VDD = 2.7 V to 5.25 V, VDRIVE = 2.7 V to 5.25 V, Reference = 2.5 V External on DCAPA and DCAPB, fSCLK = 20 MHz, unless otherwise noted.) Parameter A Version1 B Version1 Unit Test Conditions/Comments
DYNAMIC PERFORMANCE Signal to Noise + Distortion (SINAD)2 68 68 dB min fIN = 300 kHz Sine Wave, fS = 1 MSPS Total Harmonic Distortion (THD)2 –75 –75 dB max fIN = 300 kHz Sine Wave, fS = 1 MSPS Peak Harmonic or Spurious Noise (SFDR)2 –76 –76 dB max fIN = 300 kHz Sine Wave, fS = 1 MSPS Intermodulation Distortion (IMD)2 Second Order Terms –88 –88 dB typ Third Order Terms –88 –88 dB typ Channel-to-Channel Isolation –88 –88 dB typ SAMPLE AND HOLD Aperture Delay3 10 10 ns max Aperture Jitter3 50 50 ps typ Aperture Delay Matching3 200 200 ps max Full Power Bandwidth 12 12 MHz typ @ 3 dB 2 2 MHz typ @ 0.1 dB DC ACCURACY Resolution 12 12 Bits Integral Nonlinearity ±1.5 ±1 LSB max B Grade, 0 V to VREF Range Only; ±0.5 LSB typ ±1.5 LSB max 0 V to 2 VREF Range; ± 0.5 LSB typ Differential Nonlinearity –0.95/+1.25 –0.95/+1.25 LSB max Guaranteed No Missed Codes to 12 Bits 0 V to VREF Input Range Straight Binary Output Coding Offset Error ±8 ±8 LSB max Offset Error Match ±1.2 ±1.2 LSB typ Gain Error ±2.5 ±2.5 LSB max Gain Error Match ±0.2 ±0.2 LSB typ 2 VREF Input Range –VREF to +VREF Biased about VREF with Positive Gain Error ±2.5 ±2.5 LSB max Twos Complement Output Coding Zero Code Error ±8 ±8 LSB max Zero Code Error Match ±0.2 ±0.2 LSB typ Negative Gain Error ±2.5 ±2.5 LSB max ANALOG INPUT Input Voltage Ranges 0 to VREF 0 to VREF V RANGE Pin Low upon CS Falling Edge 0 to 2 VREF 0 to 2 VREF V RANGE Pin High upon CS Falling Edge DC Leakage Current ±500 ±500 nA max TA = –40C to +85C 1 1 µA max 85C < TA ≤ 125C Input Capacitance 30 30 pF typ When in Track 10 10 pF typ When in Hold REFERENCE INPUT/OUTPUT Reference Input Voltage 2.5 2.5 V ±1% for Specified Performance Reference Input Voltage Range4 2/3 2/3 V min/V max REF SELECT Pin Tied High DC Leakage Current ±30 ±30 µA max VREF Pin ±160 ±160 µA max DCAPA, DCAPB Pins Input Capacitance 20 20 pF typ Reference Output Voltage5 2.45/2.55 2.45/2.55 V min/V max VREF Output Impedance6 25 25 Ω typ VDD = 5 V 45 45 Ω typ VDD = 3 V Reference Temperature Coefficient 50 50 ppm/°C typ REF OUT Error (TMIN to TMAX) ±15 ±15 mV typ LOGIC INPUTS Input High Voltage, VINH 0.7 VDRIVE 0.7 VDRIVE V min Input Low Voltage, VINL 0.3 VDRIVE 0.3 VDRIVE V max Input Current, I ± IN 1 ±1 µA max Typically 15 nA, VIN = 0 V or VDRIVE Input Capacitance, C 3 IN 10 10 pF max LOGIC OUTPUTS Output High Voltage, VOH VDRIVE – 0.2 VDRIVE – 0.2 V min ISOURCE = 200 µA Output Low Voltage, VOL 0.4 0.4 V max ISINK = 200 µA Floating-State Leakage Current ±1 ±1 µA max VDD = 2.7 V to 5.25 V Floating-State Output Capacitance3 10 10 pF max Output Coding Straight (Natural) Binary Selectable with Either Input Range Twos Complement –2– REV. A Document Outline FEATURES GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS TERMINOLOGY Integral Nonlinearity Differential Nonlinearity Offset Error Offset Error Match Gain Error Gain Error Match Zero Code Error Zero Code Error Match Positive Gain Error Negative Gain Error Track-and-Hold Acquisition Time Signal-to-(Noise + Distortion) Ratio (SNDR) Total Harmonic Distortion (THD) Peak Harmonic or Spurious Noise Intermodulation Distortion Channel-to-Channel Isolation PSR (Power Supply Rejection) PERFORMANCE CURVES Typical Performance Characteristics CIRCUIT INFORMATION CONVERTER OPERATION ANALOG INPUT Analog Input Ranges Handling Bipolar Input Signals Transfer Functions Digital Inputs REFERENCE CONFIGURATION OPTIONS MODES OF OPERATION Normal Mode Partial Power-Down Mode Full Power-Down Mode POWER-UP TIMES POWER VS. THROUGHPUT RATE SERIAL INTERFACE MICROPROCESSOR INTERFACING AD7866 to ADSP-218x AD7866 to TMS320C541 AD7866 to DSP-563xx APPLICATION HINTS Grounding and Layout Evaluating the AD7866 Performance OUTLINE DIMENSIONS Revision History
