Datasheet AD1555, AD1556 (Analog Devices) - 3
DescriptionDigital Filter/Decimator for 24-Bit Sigma-Delta A/D Converter
Pages / Page24 / 3 — AD1555/AD1556. AD1555BP. AD1555AP. Parameter. Notes. Min. Typ. Max. Unit
RevisionB
File Format / SizePDF / 440 Kb
AD1555/AD1556 AD1555BP AD1555AP Parameter Notes Min Typ Max Unit
AD1555/AD1556 AD1555BP AD1555AP Parameter Notes Min Typ Max Min Typ Max Unit
POWER SUPPLIES Recommended Operating Conditions +VA 4.75 5 5.25 4.75 5 5.25 V –VA –5.25 –5 –4.75 –5.25 –5 –4.75 V VL 4.75 5 5.25 4.75 5 5.25 V Quiescent Currents I(+VA)10 8 10 8 10 mA I(–VA)10 8 9.5 8 9.5 mA I(VL) 30 42 30 42 µA Power Dissipation10 77 96 77 96 mW PGA in Standby Mode11 56 70 56 70 mW In Power-Down Mode11, 12 Reference Input = 3 V 650 650 µW Reference Input = 0 V 250 250 µW NOTES 1Tested at the output word rate FO = 1 kHz. FO is the AD1556 output word rate, the inverse of the sampling rate. See Tables I, Ia, Ib for other output word rates. 2Tested with a full-scale input signal at approximately 24 Hz. 3This parameter is guaranteed by design. 4Tested at the output word rate FO = 1 kHz with input signals of 30 Hz and 50 Hz, each 6 dB down full scale. 5This specification is for the AD1555 only and does not include the errors from external components as, for instance, the external reference. 6This offset specification is referred to the modulator output. 7Characterized with a 100 mV p-p sine wave applied separately to each supply. 8Contact factory for extended temperature range. 9Recommended Reference: AD780BR. 10Specified with analog inputs grounded. 11See Table III for configuration conditions. 12Specified with MCLK input grounded. Specifications subject to change without notice.
AD1556–SPECIFICATIONS (VL = 2.85 V to 5.25 V; CLKIN = 1.024 MHz; TA = TMIN to TMAX unless otherwise noted.) AD1556AS Parameter Notes Min Typ Max Unit
FILTER PERFORMANCES Pass-Band Ripple –0.05 +0.05 dB Stop-Band Attenuation All Filters Except FO =16 kHz –135 dB FO =16 kHz –86 dB Filters Characteristics See Table II DIGITAL INPUTS OUTPUTS VIL –0.3 +0.8 V VIH +2.0 VL + 0.3 V IIL –10 +10 µA IIH –10 +10 µA VOL ISINK = +2 mA +0.5 V VOH ISOURCE = –2 mA VL – 0.6 V POWER SUPPLIES Specified Performance VL 2.85 5.25 V Quiescent Currents I(VL) 4 5 mA Power Dissipation VL = 3.3 V, FO = 1 kHz 6.2 8.5 mW In Power-Down Mode 70 µW TEMPERATURE RANGE* Specified Performance, TMIN to TMAX –55 +85 °C *Contact factory for extended temperature range. Specifications subject to change without notice. REV. B –3–
