Datasheet AD7865 (Analog Devices) - 8
DescriptionFast, Low-Power, 4-Channel, Simultaneous Sampling, 14-bit ADC
Pages / Page20 / 8 — AD7865. Pin. Mnemonic. Description
File Format / SizePDF / 243 Kb
AD7865 Pin Mnemonic Description
24 VREF Reference Input/Output. This pin provides access to the internal reference (2.5 V ± 20 mV) and also allows the internal reference to be overdriven by an external reference source (2.5 V ± 5%). A 0.1 µF decoupling capacitor should be connected between this pin and AGND. 25 AVDD Analog Positive Supply Voltage, 5.0 V ± 5%. A 0.1 µF decoupling capacitor should be con- nected between this pin and AGND. 26 AGND Analog Ground. General Analog Ground. This AGND pin should be connected to the system’s AGND plane. 27–34 DB13–DB6 Data Bit 13 is the MSB, followed by Data Bit 12 to Data Bit 6. Three-state TTL outputs. Output coding is twos complement for AD7865-1 and AD7865-3, and straight binary for AD7865-2. 35 DVDD Positive Supply Voltage for Digital section, 5.0 V ± 5%. A 0.1 µF decoupling capacitor should be connected between this pin and AGND. Both DVDD and AVDD should be externally tied together. 36 VDRIVE This pin provides the positive supply voltage for the output drivers (DB0 to DB13), BUSY, EOC and FRSTDATA. It is normally tied to DVDD. VDRIVE should be decoupled with a 0.1 µF capacitor. It allows improved performance when reading during the conversion sequence. Also, the output data drivers may be powered by a 3 V ± 10% supply to facilitate interfacing to 3 V processors and DSPs. 37 DGND Digital Ground. Ground reference for Digital circuitry. This DGND pin should be connected to the system’s DGND plane. The system’s DGND and AGND planes should be connected together at one point only, preferably at an AGND pin. 38, 39 DB5, DB4 Data Bit 5 to Data Bit 4. Three-state TTL outputs. 40–43 DB3–DB0 Data Bit 3 to Data Bit 0. Bidirectional data pins. When a read operation takes place, these pins are three-state TTL outputs. The channel select register is programmed with the data on the DB0–DB3 pins with standard CS and WR signals. DB0 represents Channel 1 and DB3 represents Channel 4. 44 EOC End-of-Conversion. Active low logic output indicating conversion status. The end of each conversion in a conversion sequence is indicated by a low going pulse on this line. REV. B –7–
