link to page 9 AD772332 CLKIN CYCLESCLKINt8FSIt14SCO(CFMT = 0)tt111216 CLKIN CYCLES16 CLKIN CYCLESFSOt13 006 SDOD3D2D1D0D15D14D13D3D2D1D0D15D14D13D3D2D1D0D15 01186- Figure 6. Serial Mode 3: Timing for Frame Sync Input, Frame Sync Output, Serial Clock Output, and Serial Data Output (See Table 3 for Control Inputs, TSI = DOE) Table 3. Serial Interface (MODE1 = 0, MODE2 = 0)ControlInputsSerial ModeDecimation Ratio (SLDR)Digital Filter Mode (SLP)SCO Frequency (SCR)Output Data RateSLDRSLPSCR 1 32 Low Pass fCLKIN fCLKIN/32 1 1 0 1 32 Band Pass fCLKIN fCLKIN/32 1 0 0 2 32 Low Pass fCLKIN/2 fCLKIN/32 1 1 1 2 32 Band Pass fCLKIN/2 fCLKIN/32 1 0 1 3 16 Low Pass fCLKIN fCLKIN/16 0 1 0 Table 4. Parallel InterfaceControlInputsDigital Filter ModeDecimation RatioOutput Data RateMODE1MODE2 Band Pass 32 fCLKIN/32 0 1 Low Pass 32 fCLKIN/32 1 0 Low Pass 16 fCLKIN/16 1 1 DOEtt1615SDO 01186-007 Figure 7. Serial Mode Timing for Data Output Enable and Serial Data Output Rev. C | Page 8 of 32 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION APPLYING THE AD7723 ANALOG INPUT RANGE ANALOG INPUT DRIVING THE ANALOG INPUTS APPLYING THE REFERENCE CLOCK GENERATION SYSTEM SYNCHRONIZATION DATA INTERFACING PARALLEL INTERFACE SERIAL INTERFACE TWO-CHANNEL MULTIPLEXED OPERATION SERIAL INTERFACE TO DSPs AD7723 TO ADSP-21xx INTERFACE AD7723 TO SHARC INTERFACE AD7723 TO DSP56002 INTERFACE AD7723 TO TMS320C5x INTERFACE GROUNDING AND LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
