Datasheet AD9260 (Analog Devices) - 2
Description16-Bit High Speed Oversampled A/D Converter
Pages / Page45 / 2 — AD9260* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
AD9260* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. DOCUMENTATION
AD9260* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS DOCUMENTATION
View a parametric search of comparable parts. • Visual Analog
DOCUMENTATION REFERENCE MATERIALS Application Notes Technical Articles
• AN-202: An IC Amplifier User’s Guide to Decoupling, • MS-2210: Designing Power Supplies for High Speed ADC Grounding, and Making Things Go Right for a Change • Understanding Continuous-Time, Discrete-Time Sigma- • AN-282: Fundamentals of Sampled Data Systems Delta ADCs And Nyquist ADCs • AN-311: How to Reliably Protect CMOS Circuits Against Power Supply Overvoltaging
DESIGN RESOURCES
• AN-345: Grounding for Low-and-High-Frequency Circuits • AD9260 Material Declaration • AN-397: Electrically Induced Damage to Standard Linear • PCN-PDN Information Integrated Circuits: • Quality And Reliability • AN-501: Aperture Uncertainty and ADC System • Symbols and Footprints Performance • AN-715: A First Approach to IBIS Models: What They Are
DISCUSSIONS
and How They Are Generated • AN-737: How ADIsimADC Models an ADC View all AD9260 EngineerZone Discussions. • AN-741: Little Known Characteristics of Phase Noise
SAMPLE AND BUY
• AN-756: Sampled Systems and the Effects of Clock Phase Noise and Jitter Visit the product page to see pricing options. • AN-835: Understanding High Speed ADC Testing and Evaluation
TECHNICAL SUPPORT
• AN-905: Visual Analog Converter Evaluation Tool Version Submit a technical question or find your regional support 1.0 User Manual number. • AN-935: Designing an ADC Transformer-Coupled Front End
DOCUMENT FEEDBACK Data Sheet
Submit feedback for this data sheet. • AD9260: High Speed Oversampling CMOS ADC with 16- Bit Resolution at a 2.5 MHz Output Word Rate Data Sheet
Document Outline FEATURES PRODUCT DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS CLOCK INPUT FREQUENCY RANGE DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL FILTER CHARACTERISTICS DIGITAL FILTER CHARACTERISTICS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION TERMINOLOGY PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TYPICAL AC CHARACTERIZATION CURVES VS. DECIMATION MODE TYPICAL AC CHARACTERIZATION CURVES FOR 8× MODE TYPICAL AC CHARACTERIZATION CURVES FOR 4× MODE TYPICAL AC CHARACTERIZATION CURVES FOR 2× MODE TYPICAL AC CHARACTERIZATION CURVES FOR 1× MODE TYPICAL AC CHARACTERIZATION CURVES ADDITIONAL AC CHARACTERIZATION CURVES THEORY OF OPERATION ANALOG INPUT AND REFERENCE OVERVIEW INPUT SPAN INPUT COMPLIANCE RANGE ANALOG INPUT OPERATION DRIVING THE INPUT Transient Response Input Driver Considerations Single-Ended-to-Differential Op Amp Driver Common-Mode Level REFERENCE OPERATION DIGITAL INPUTS AND OUTPUTS DIGITAL OUTPUTS CS and Read Pins DAV Pin RESET Pin OTR Pin MODE OPERATION BIAS PIN OPERATION POWER DISSIPATION CONSIDERATIONS DIGITAL OUTPUT DRIVER CONSIDERATIONS (DRVDD) Clock Input and Considerations GROUNDING AND DECOUPLING Analog and Digital Grounding Analog and Digital Supply Decoupling EVALUATION BOARD GENERAL DESCRIPTION FEATURES AND USER CONTROLS Jumper Controlled Mode/OSR Selection Selectable Power Bias Data Interfacing Controls Buffered Output Data Jumper Controlled Reference Source Flexible DC or AC Coupled External Clock Inputs Flexible Input Signal Configuration Circuitry Selecting Single or Dual Signal Input Selectable Input Signal Common-Mode Level Source SHIPMENT CONFIGURATION QUICK SETUP APPLICATION INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
