AD7858/AD7858LABSOLUTE MAXIMUM RATINGS1 SOIC, SSOP Package, Power Dissipation . 450 mW (T θ A = +25°C unless otherwise noted) JA Thermal Impedance . 75°C/W (SOIC) 115°C/W (SSOP) θ AV JC Thermal Impedance . 25°C/W (SOIC) 35°C/W (SSOP) DD to AGND . –0.3 V to +7 V DV Lead Temperature, Soldering DD to DGND . –0.3 V to +7 V AV Vapor Phase (60 sec) . +215°C DD to DVDD . –0.3 V to +0.3 V Analog Input Voltage to AGND . –0.3 V to AV Infrared (15 sec) . +220°C DD + 0.3 V Digital Input Voltage to DGND . –0.3 V to DV NOTES DD + 0.3 V 1 Digital Output Voltage to DGND . –0.3 V to DV Stresses above those listed under Absolute Maximum Ratings may cause perma- DD + 0.3 V nent damage to the device. This is a stress rating only; functional operation of the REFIN/REFOUT to AGND . –0.3 V to AVDD + 0.3 V device at these or any other conditions above those listed in the operational Input Current to Any Pin Except Supplies2 . ± 10 mA sections of this specification is not implied. Exposure to absolute maximum rating Operating Temperature Range conditions for extended periods may affect device reliability. Commercial (A, B Versions) . –40°C to +85°C 2Transient currents of up to 100 mA will not cause SCR latch-up. Storage Temperature Range . –65°C to +150°C Junction Temperature . +150°C Plastic DIP Package, Power Dissipation . 450 mW θJA Thermal Impedance . 105°C/W θJC Thermal Impedance . 34.7°C/W Lead Temperature, (Soldering, 10 sec) . +260°C CAUTION ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection. Although WARNING! the AD7858/AD7858L features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD precautions ESD SENSITIVE DEVICE are recommended to avoid performance degradation or loss of functionality. ORDERING GUIDEPIN CONFIGURATIONSDIP, SOIC, AND SSOPLinearityPowerErrorDissipation PackageModel(LSB)1(mW)Options2CONVST 124 SYNC AD7858AN ±1 20 N-24 BUSY 223 SCLK AD7858BN ±1/2 20 N-24 SLEEP 322 CLKIN AD7858LAN3 ±1 6.85 N-24 REFIN/REFOUT 421 DINAD7858/AV AD7858LBN3 ±1 6.85 N-24 DD520AD7858LDOUT AD7858AR ±1 20 R-24 AGND 619TOP VIEWDGND(Not to Scale) AD7858BR ±1/2 20 R-24 C7REF118 DVDD AD7858LAR3 ±1 6.85 R-24 C8REF217 CAL AD7858LBR3 ±1 6.85 R-24 AIN1 916 AIN8 AD7858LARS3 ±1 6.85 RS-24 AIN2 1015 AIN7AIN3 EVAL-AD7858CB4 1114 AIN6 EVAL-CONTROL BOARD5 AIN4 1213 AIN5 NOTES 1Linearity error here refers to integral linearity error. 2N = Plastic DIP; R = SOIC; RS = SSOP. 3L signifies the low-power version. 4This can be used as a stand-alone evaluation board or in conjunction with the EVAL- CONTROL BOARD for evaluation/demonstration purposes. 5This board is a complete unit allowing a PC to control and communicate with all Analog Devices evaluation boards ending in the CB designators. –6– REV. B
