Datasheet AD5383 (Analog Devices) - 3
Description32-Channel, 3 V/5 V, Single-Supply, 12-Bit, denseDAC
Pages / Page41 / 3 — AD5383. Data Sheet. TABLE OF CONTENTS
RevisionD
File Format / SizePDF / 773 Kb
AD5383 Data Sheet TABLE OF CONTENTS
link to page 1 link to page 1 link to page 1 link to page 1 link to page 4 link to page 5 link to page 6 link to page 6 link to page 8 link to page 9 link to page 10 link to page 10 link to page 12 link to page 13 link to page 15 link to page 15 link to page 16 link to page 19 link to page 20 link to page 23 link to page 23 link to page 23 link to page 24 link to page 24 link to page 27 link to page 27 link to page 27 link to page 27 link to page 27 link to page 27 link to page 27 link to page 28 link to page 28 link to page 30 link to page 32 link to page 33 link to page 35 link to page 35 link to page 35 link to page 36 link to page 37 link to page 37 link to page 37 link to page 38 link to page 39 link to page 40 link to page 40
Features .. 1 Hardware Functions ... 26 Integrated Functions .. 1 Reset Function .. 26 Applications ... 1 Asynchronous Clear Function .. 26 Functional Block Diagram .. 1 BUSY and LDAC Functions.. 26 Revision History ... 3 FIFO Operation in Parallel Mode .. 26 General Description ... 4 Power-On Reset .. 26 Specifications ... 5 Power-Down ... 26 AD5383-5 Specifications ... 5 Interfaces.. 27 AD5383-3 Specifications ... 7 DSP-, SPI-, MICROWIRE-Compatible Serial Interfaces ... 27 AC Characteristics .. 8 I2C Serial Interface ... 29 Timing Characteristics ... 9 Parallel Interface ... 31 Serial Interface Timing .. 9 Microprocessor Interfacing ... 32 I2C Serial Interface Timing.. 11 Applications Information .. 34 Parallel Interface Timing ... 12 Power Supply Decoupling ... 34 Absolute Maximum Ratings .. 14 Power Supply Sequencing ... 34 ESD Caution .. 14 Typical Configuration Circuit .. 35 Pin Configuration and Function Descriptions ... 15 Channel Monitor Function ... 36 Terminology .. 18 Toggle Mode Function ... 36 Typical Performance Characteristics ... 19 Thermal Monitor Function ... 36 Functional Description .. 22 Optical Attenuators .. 37 DAC Architecture—General ... 22 Utilizing the FIFO .. 38 Data Decoding .. 22 Outline Dimensions ... 39 On-Chip Special Function Registers (SFR) .. 23 Ordering Guide .. 39 SFR Commands .. 23 Rev. D | Page 2 of 40 Document Outline Features Integrated Functions Applications Functional Block Diagram Table of Contents Revision History General Description Specifications AD5383-5 Specifications AD5383-3 Specifications AC Characteristics9F Timing Characteristics Serial Interface Timing I2C Serial Interface Timing Parallel Interface Timing Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Terminology Typical Performance Characteristics Functional Description DAC Architecture—General Data Decoding On-Chip Special Function Registers (SFR) SFR Commands NOP (No Operation) Write CLR Code Soft CLR Soft Power-Down Soft Power-Up Soft RESET Control Register Write/Read Channel Monitor Function Hardware Functions Reset Function Asynchronous Clear Function BUSY\ and LDAC\ Functions FIFO Operation in Parallel Mode Power-On Reset Power-Down Interfaces DSP-, SPI-, MICROWIRE-Compatible Serial Interfaces Standalone Mode Daisy-Chain Mode Readback Mode I2C Serial Interface I2C Data Transfer START and STOP Conditions Repeated START Conditions Acknowledge Bit (ACK) AD5383 Slave Addresses Write Operation 4-Byte Mode 3-Byte Mode 2-Byte Mode Parallel Interface CS\ Pin WR\ Pin REG0, REG1 Pins Pins A4 to A0 Pins DB11 to DB0 Microprocessor Interfacing Parallel Interface AD5383 to MC68HC11 AD5383 to PIC16C6x/7x AD5383 to 8051 AD5383 to ADSP-BF527 Applications Information Power Supply Decoupling Power Supply Sequencing Typical Configuration Circuit Channel Monitor Function Toggle Mode Function Thermal Monitor Function Optical Attenuators Utilizing the FIFO Outline Dimensions Ordering Guide
