Datasheet AD558 Military (Analog Devices) - 2
Pages / Page11 / 2 — STANDARD. 5962-87789. MICROCIRCUIT DRAWING
File Format / SizePDF / 115 Kb
STANDARD 5962-87789 MICROCIRCUIT DRAWING
1. SCOPE 1.1 Scope. This drawing describes device requirements for MIL-STD-883 compliant, non-JAN class level B microcircuits in accordance with MIL-PRF-38535, appendix A. 1.2 Part or Identifying Number (PIN). The complete PIN is as shown in the following example: 5962-87789 01 E A Drawing number Device type Case outline Lead finish (see 1.2.1) (see 1.2.2) (see 1.2.3) 1.2.1 Device types. The device types identify the circuit function as follows: Device type Generic number Circuit function 01 AD558S 8-bit D/A with full microprocessor interface 02 AD558T 8-bit D/A with full microprocessor interface 1.2.2 Case outlines. The case outlines are as designated in MIL-STD-1835 and as follows: Outline letter Descriptive designator Terminals Package style E GDIP1-T16 or CDIP2-T16 16 Dual-in-line 2 CQCC1-N20 20 Square leadless chip carrier 1.2.3 Lead finish. The lead finish is as specified in MIL-PRF-38535, appendix A. 1.3 Absolute maximum ratings. Positive supply voltage VCC to digital return ... 0 V dc to +18 V dc Digital input voltage to digital return ... 0 V dc to +7.0 V dc Output short circuit duration (to ground) .. Indefinite Output short circuit duration (to VCC) ... Momentary Power dissipation... 450 mW Lead temperature (soldering, 10 seconds) .. +300C Storage temperature range .. -65C to +150C Junction temperature (TJ) .. +175C Thermal resistance, junction-to-case (JC) ... See MIL-STD-1835 Thermal resistance, junction-to-ambient (JA): Case outline E .. 100C/W Case outline 2 .. 120C/W 1.4 Recommended operating conditions. Positive supply voltage range (VCC): 2.56 V output range .. 4.5 V dc to 5.5 V dc 10 V output range ... 11.4 V dc to 16.5 V dc Ambient operating temperature range (TA) .. -55C to +125C SIZE
STANDARD A 5962-87789 MICROCIRCUIT DRAWING
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C
2
DSCC FORM 2234 APR 97
