Datasheet AD558 Military (Analog Devices) - 4
Pages / Page11 / 4 — STANDARD. 5962-87789. MICROCIRCUIT DRAWING
File Format / SizePDF / 115 Kb
STANDARD 5962-87789 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics. Conditions 1/ Group A Device Test Symbol Limits Unit -55°C ≤ TA ≤ +125°C subgroups type unless otherwise specified Min Max Relative accuracy RA 1 All 0.50 LSB All bits with positive errors on and all bits with negative 2, 3 01  errors on 0.75 12 02 0.25 2, 3 0.375 Differential nonlinearity DNL All major carriers 1, 2, 3 All 1 LSB Zero error VZE All bits off 1 All 1 LSB 2, 3 01 2 12 02 0.5 2, 3 1 Gain error AE 1 All  No load and 5 mA load, all 1.5 LSB bits on 2, 3 01 2.5 12 02 0.5 2, 3 1.0 t Output voltage settling VO 0 to 10 V range 2/ 7 All 3.0 s time (settling) 8 5.0 3/ 0 to 2.56 V range 2/ 7 All 1.5 8 3.0 Power supply rejection PSRR 4/ 1, 2, 3 All 0.03 %/% ratio Power supply current ICC All bits on 1, 2, 3 All 25 mA Digital input high voltage VIH 1, 2, 3 All 2.0 V Digital input low voltage VIL 1, 2, 3 All 0.8 V Functional tests 3/ See 4.3.1c 7, 8 All See footnotes at end of table. SIZE
STANDARD A 5962-87789 MICROCIRCUIT DRAWING
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C
4
DSCC FORM 2234 APR 97
