Datasheet ADL5567 (Analog Devices) - 6
Description4.3 GHz, Ultrahigh Dynamic Range, Dual Differential Amplifier
Pages / Page25 / 6 — ADL5567. Data Sheet. Test Conditions/. VS = 3.3 V. VS = 5 V. Parameter. …
File Format / SizePDF / 869 Kb
ADL5567. Data Sheet. Test Conditions/. VS = 3.3 V. VS = 5 V. Parameter. Comments. Min. Typ. Max. Unit
ADL5567 Data Sheet Test Conditions/ VS = 3.3 V VS = 5 V Parameter Comments Min Typ Max Unit
link to page 7 link to page 7 link to page 7
ADL5567 Data Sheet Test Conditions/ VS = 3.3 V VS = 5 V Parameter Comments Min Typ Max Min Typ Max Unit
Supply Current (ISUPPLY) Total for two channels High Performance Mode ENBLx = high, PMx = low 138 150 148 160 mA Low Power Mode ENBLx = high, PMx = high 80 85 mA Disabled (Power Down) ENBLx = low, PMx = don't 7 9 mA care NOISE/HARMONIC PERFORMANCE 10 MHz Second Harmonic Distortion (HD2) −88 −93 dBc Third Harmonic Distortion (HD3) −90 −94 dBc Output Third-Order Intercept 42.6 46.3 dBm (OIP3) Third-Order Intermodulation −89 −97 dBc Distortion (IMD3) Output Second-Order Intercept 90.2 90.9 dBm (OIP2) Second-Order Intermodulation −92 −93 dBc Distortion (IMD2) Output 1 dB Compression Point 12.8 16.6 dBm (OP1dB) Noise Figure (NF) 6.7 6.8 dB Noise Spectral Density (NSD), 1.21 1.23 nV/√Hz Referred to Input (RTI)1 100 MHz HD2 −88 −94 dBc HD3 −89 −101 dBc OIP3 42.5 46.5 dBm IMD3 −89 −97 dBc OIP2 84.5 94.2 dBm IMD2 −87 −96 dBc OP1dB 13.0 16.9 dBm NF 6.8 6.8 dB NSD, RTI1 1.23 1.23 nV/√Hz 200 MHz HD2 −88 −94 dBc HD3 −86 −103 dBc OIP3 43.5 49.8 dBm IMD3 −91 −104 dBc OIP2 80.7 88.8 dBm IMD2 −83 −91 dBc OP1dB, Referred to Output (RTO) 12.6 16.7 dBm NF 7.0 7.1 dB NSD, RTI 1.27 1.29 nV/√Hz 500 MHz2 HD2 −77 −82 dBc HD3 −70 −82 dBc OIP3 37 42.8 dBm IMD3 −78 −90 dBc OIP2 76.7 82.0 dBm IMD2 −79 −84 dBc NF 7.3 7.4 dB NSD, RTI 1.32 1.34 nV/√Hz Rev. 0 | Page 4 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS INPUT AND OUTPUT INTERFACING Single-Ended Input to Differential Output INPUT AND OUTPUT EQUIVALENT CIRCUITS GAIN ADJUSTMENT AND INTERFACING EFFECT OF LOAD CAPACITANCE ADC INTERFACING SOLDERING INFORMATION AND RECOMMENDED LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
