Datasheet ADL5566 (Analog Devices)
Description4.5 GHz Ultrahigh Dynamic Range, Dual Differential Amplifier
Pages / Page25 / 1 — 4.5 GHz Ultrahigh Dynamic Range,. Dual Differential Amplifier. Data …
RevisionA
File Format / SizePDF / 838 Kb
4.5 GHz Ultrahigh Dynamic Range,. Dual Differential Amplifier. Data Sheet. ADL5566. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADL5566 Analog Devices, Revision: A
4.5 GHz Ultrahigh Dynamic Range, Dual Differential Amplifier Data Sheet ADL5566 FEATURES FUNCTIONAL BLOCK DIAGRAM −3 dB bandwidth of 4.5 GHz (A VCC1/VCC2 ENBL1 V = 16 dB) Fixed 16 dB gain Channel-to-channel gain error: 0.1 dB at 100 MHz RF Channel-to-channel phase error: 0.06° at 100 MHz Differential or single-ended input to differential output VON1 I/O dc-coupled or ac-coupled Low noise input stage: 1.3 nV/√Hz RTI at A RG V = 16 dB VIP1 VCOM1 Low broadband distortion (A R V = 16 dB), supply = 5 V G VIN1 10 MHz: −103 dBc (HD2), −107 dBc (HD3) 100 MHz: −95 dBc (HD2), −100 dBc (HD3) 200 MHz: −94.5 dBc (HD2), −87 dBc (HD3) VOP1 500 MHz: −83 dBc (HD2), −64 dBc (HD3) RF IMD3 of −95 dBc at 200 MHz center Maintains low single-ended distortion performance out to RF 500 MHz Slew rate: 16 V/ns VON2 Maintains low distortion down to 1.2 V VCOM Fixed 16 dB gain can be reduced by adding external resistors RG VIP2 VCOM2 Fast settling and overdrive recovery of 2.5 ns RG Single-supply operation: 2.8 V to 5.2 V VIN2 Power-down Low dc power consumption, 462 mW at 3.3 V supply VOP2 APPLICATIONS RF Differential ADC drivers ADL5566
001
Single-ended-to-differential conversion RF/IF gain blocks GND ENBL2
10916-
SAW filter interfacing
Figure 1.
GENERAL DESCRIPTION
The ADL5566 is a high performance, dual differential amplifier The quiescent current of the ADL5566, using a 3.3 V supply, is optimized for IF and dc applications. The amplifier offers low typically 70 mA per amplifier. When disabled, it consumes less noise of 1.3 nV/√Hz and excellent distortion performance over than 3.5 mA per amplifier and has −25 dB of input-to-output a wide frequency range, making it an ideal driver for high speed isolation at 100 MHz. 16-bit analog-to-digital converters (ADCs). The ADL5566 is The device is optimized for wideband, low distortion, and noise ideally suited for use in high performance, zero IF/complex performance, giving it unprecedented performance for overall IF receiver designs. In addition, this device has excellent low spurious-free dynamic range (SFDR). These attributes, together distortion for single-ended input drive applications. with its adjustable gain capability, make this device the amplifier The ADL5566 provides a gain of 16 dB. For the single-ended input of choice for driving a wide variety of ADCs, mixers, pin diode configuration, the gain is reduced to 14 dB. Using two external attenuators, SAW filters, and multi-element discrete devices. series resistors for each amplifier expands the gain flexibility of Fabricated on an Analog Devices, Inc., high speed SiGe process, the the amplifier and al ows for any gain selection from 0 dB to 16 dB ADL5566 is supplied in a compact 4 mm × 4 mm, 24-lead LFCSP for a differential input and 0 dB to 14 dB for a single-ended input. package and operates over the −40°C to +85°C temperature range. In addition, this device maintains low distortion down to output (VOCM) levels of 1.2 V providing an added capability for driving CMOS ADCs at ac levels up to 2 V p-p.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2012–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description Applications Information Basic Connections Input and Output Interfacing Single-Ended Input to Differential Output Gain Adjustment and Interfacing ADC Interfacing DC-Coupled Receiver Application Layout Considerations Soldering Information and Recommended Land Pattern Evaluation Board Outline Dimensions Ordering Guide
