Datasheet ADL5565 (Analog Devices) - 8
Description6 GHz Ultrahigh Dynamic Range Differential Amplifier
Pages / Page29 / 8 — Data Sheet. ADL5565. Parameter. Test Conditions/Comments. Min. Typ. Max …
RevisionG
File Format / SizePDF / 909 Kb
Data Sheet. ADL5565. Parameter. Test Conditions/Comments. Min. Typ. Max Unit
Data Sheet ADL5565 Parameter Test Conditions/Comments Min Typ Max Unit
NOISE/HARMONIC PERFORMANCE 10 MHz Second/Third Harmonic Distortion (HD2/HD3) AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −111/−116 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −100/−104 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −105/−106 dBc Output IP3/Third-Order Intermodulation AV = 6 dB, RL = 200 Ω, VOUT = +47/−98 dBm/dBc Distortion (OIP3/IMD3) 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = +50/−104 dBm/dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = +50/−104 dBm/dBc 2 V p-p composite (2 MHz spacing) Second-Order Intermodulation Distortion (IMD2) AV = 6 dB, RL = 200 Ω, VOUT = −78 dBc 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = −86 dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = −91 dBc 2 V p-p composite (2 MHz spacing) Noise Spectral Density, RTI (NSD) AV = 6 dB 2.25 nV/√Hz AV = 12 dB 1.54 nV/√Hz AV = 15.5 dB 1.55 nV/√Hz Noise Figure (NF) AV = 6 dB 10.29 dB AV = 12 dB 8.77 dB AV = 15.5 dB 9.04 dB 1 dB Compression Point, RTO (OP1dB) AV = 6 dB 16.8 dBm AV = 12 dB 16.7 dBm AV = 15.5 dB 16.6 dBm 100 MHz Second/Third Harmonic Distortion (HD2/HD3) AV = 6 dB, RL = 200 Ω, VOUT = 2 V p-p −108/−109 dBc AV = 12 dB, RL = 200 Ω, VOUT = 2 V p-p −92/−103 dBc AV = 15.5 dB, RL = 200 Ω, VOUT = 2 V p-p −89.5/−105 dBc Output IP3/Third-Order Intermodulation AV = 6 dB, RL = 200 Ω, VOUT = +53/−110 dBm/dBc Distortion (OIP3/IMD3) 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = +53/−110 dBm/dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = +52/−108 dBm/dBc 2 V p-p composite (2 MHz spacing) Second-Order Intermodulation Distortion (IMD2) AV = 6 dB, RL = 200 Ω, VOUT = −87 dBc 2 V p-p composite (2 MHz spacing) AV = 12 dB, RL = 200 Ω, VOUT = −91 dBc 2 V p-p composite (2 MHz spacing) AV = 15.5 dB, RL = 200 Ω, VOUT = −87 dBc 2 V p-p composite (2 MHz spacing) Noise Spectral Density, RTI (NSD) AV = 6 dB 2.28 nV/√Hz AV = 12 dB 1.53 nV/√Hz AV = 15.5 dB 1.52 nV/√Hz Noise Figure (NF) AV = 6 dB 10.39 dB AV = 12 dB 8.73 dB AV = 15.5 dB 8.7 dB 1 dB Compression Point, RTO (OP1dB) AV = 6 dB 16.8 dBm AV = 12 dB 16.5 dBm AV = 15.5 dB 16.4 dBm Rev. E | Page 7 of 28 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 3.3 V Specifications 5 V Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Circuit Description Basic Structure Applications information Basic Connections Input and Output Interfacing Single-Ended Input to Differential Output Gain Adjustment and Interfacing ADC Interfacing Layout Considerations Soldering Information and Recommended PCB Land Pattern Evaluation Board Outline Dimensions Ordering Guide
